Is there a remedy for my Pro Rock'r instability? - Jemsite
post #1 of 9 (permalink) Old 07-30-2007, 11:39 PM Thread Starter
Post Is there a remedy for my Pro Rock'r instability?
I have a Pro Line 1660 with a Pro Rock'r trem and after I bend a string and release it the string does not return to pitch. It takes a quick karate-chop to the trem arm to get the string to return to pitch.
I have the trem set to float, set up with .009s (D'addario EXL120), and 3 spring in the back. I tried using Rich's procedure regarding fine tuning and lock-down, but it did not alleviate my tuning issues.
Any suggestions?
Thanks!
Zerimas is offline
post #2 of 9 (permalink) Old 07-31-2007, 12:33 AM
Re: Is there a remedy for my Pro Rock'r instability?
The Pro Rock'r trem was unfortunately never great (Ibanez were basically trying to avoid paying Floyd Rose royalties at the time) - about the only thing you might try is to lubricate the knife edge with a bit of chap stick - if you have followed all of Rich's tips and that doesn't help, well, maybe you should look into ditching the existing trem and sourcing an Edge - no idea how complicated it would be to retrofit, but probably not easy.
David McCarroll is offline
post #3 of 9 (permalink) Old 07-31-2007, 01:33 PM Thread Starter
I'll try lubricating the knife edges. This is quite frustrating because the trem returns to pitch reasonably well after dives and pull ups. Would some kind of trem-setting device, such as and ESP arming adjuster or Hipshot Trem-setter, help?
I've noticed that this problem seems to affect the g-string (ha ha) pretty much exclusively, why is this? The G-string returns to pitch adequately after dives and pull-ups.
Zerimas is offline
post #4 of 9 (permalink) Old 07-31-2007, 03:36 PM Thread Starter
I've noticed that whenever I bend the G-string it moves the trem forward the least when compared to the other strings. Would changing the spring formation so that there is less/more tension around the string fix the problem? My hypothesis is based on the fact that the G disturbs the trem's resting position the least and it has the worst return to pitch from bends. Is there a connection?
Zerimas is offline
post #5 of 9 (permalink) Old 07-31-2007, 04:41 PM
I have my springs set up like this;
Claw
Block
That seems to be a pretty well balanced combination. Also, are your trem springs worn out? That could be the problem.
Salamander In The Sun is offline
post #6 of 9 (permalink) Old 07-31-2007, 10:05 PM Thread Starter
Claw
Block
That's how I had my trem setup. I removed the middle spring to test my hypothesis; it seems to have made no difference.
Zerimas is offline
post #7 of 9 (permalink) Old 03-25-2012, 03:06 PM
Anyone want to revisit this topic with me? Exact same situation on an 85 DT-350. G-string returns horribly out of pitch with pro rock'r tremolo.
Thanks in advance.
massatari is offline
post #8 of 9 (permalink) Old 03-31-2012, 10:41 PM
^^ I assume you've got everything locked down at the headstock etc. If so, I'd guess it's probably friction at the nut. Try running some pencil lead in the slot for a coating of graphite, that should help a bit. If it's still bad, maybe enlarging the nut slot a little.
The other problem is, of course, the pivot points. The trem is impregnated with round pins that pivot on concave studs, creating a larger friction area than a conventional knife edge trem. Lubing it with Chapstick or something might help a bit (as mentioned above), but the trem design is simply unforgiving.
Ashurbanipal is offline
post #9 of 9 (permalink) Old 09-01-2012, 07:30 AM
I have this bridge on a 1985 DT-380 Destroyer (safari red, wheee~) and the bridge doesn't seem to return to neutral. The non-recessed routing allows only a few millimeters of upwards movement when pulling the trem arm, but it's enough to make the strings return sharp, and pushing down makes them return flat. A slight tap on the arm returns them to neutral, so I guess the posts and knife edges are to blame. I'll have to try adding another spring first since I don't have any decent lubricant at hand at the moment.
I also removed the bridge to check the post anchors, and the other one had surfaced from it's hole, breaking the finish and tearing a few splinters of wood. I hammered it back in, but I guess I should've put some glue in it. Nevertheless it didn't wiggle around in it's hole so I guess it's not an issue unless it starts to surface again.
The posts themselves did wiggle a bit, but I fixed this with plumber's tape.
UPDATE: in the absence of lip balm I put some sewing machine oil to the studs and knife edges. Didn't work.
Norjen is offline
addario exl , esp arming adjuster , floyd rose , trem arm , trem springs
Human Verification
Similar Searches
WTB: Ibanez Pro Rock'r Bridge pinto79 Classified Ads: Guitars and Gear 3 05-25-2007 02:09 PM
Setting up a Pro Rock'R Bridge blackhat2112 Tech: Setup, Repairs and Mods 1 09-11-2005 01:22 PM
Ibanez Pro Rock'R bridge? Brake Other Ibanez Guitars (including Premiums) 4 08-13-2005 02:29 PM
Creaking neck and Tuning instability LimHae Tech: Setup, Repairs and Mods 3 06-01-2003 11:50 AM
Tuning Instability! Chris2004 Tech: Setup, Repairs and Mods 3 03-09-2003 02:14 PM
