Old 08-25-2008, 03:47 AM
Shredder87  is offline
Posts: 417  -  iTrader: (0)
Thinking of changing string gauges on my RG2550
Hi everyone, would appreciate some advice here.
Have been using standard 9-42s on my RG2550 since new (guitar now 3 years old). However after a period of inactivity I may be gigging again with my band soon (have spent much of the past 2 years playing at home), and I feel that 9s can feel a little... inadequate sometimes. So I thought of upgrading to 9-46s or 10-46s for gigging. Also would build my calluses up a bit more. I have 9-46s on my other electric (Strat).
The reason I seek advice however is how would this affect the setup of the floating trem? It's a 2005 RG2550 so it has the Edge-Pro 2. It has had 9-42s on it since day one so how would this affect the setup were I to go up to 9-46s or 10s? The reason I ask is in the guitar's manual it states that the EP2 is "optimized for 9-42 gauge strings"... so would a heavier set affect the operation of the? Would I need more trem springs (currently have 3)? Would it just be a case of adjusting the angle of the bridge? Also how would the neck cope with the extra tension? The neck is of course very thin so I'm worried about it warping.
Will it be OK just to go ahead and upgrade to 9-46s or 10-46s? Sorry for bombarding you all with questions, however I just want to be sure before I change my string set.
Many thanks,
Shredder87
Old 08-25-2008, 12:58 PM
Ayrton  is offline
Re: Thinking of changing string gauges on my RG2550
Three springs will work just fine with 10s, and I know guys who use 11s on an Ibanez with no issues.
You may have to make some minor adjustments with the claw to get the trem back where it is now, but nothing you can't handle.
Old 08-25-2008, 08:01 PM
kaizzen  is offline
Posts: 54  -  iTrader: (0)
Thanks for posting this question Shredder 87.. I bought another Ibanez.. Both with 9s... I want to put 10s on the other one.
Thanks for answering Ayrton.... If another spring were to be attached does that mean you must 'drill' into the block to create a 4th spring hole? (Edge pro)
Cheers
Old 08-25-2008, 11:17 PM
70Seven  is offline
Posts: 204  -  iTrader: (0)
I have a 2006 RG2550 that had 9-42 for two years now and I just installed 9-46 this weekend. I tuned it half step down. I had to screw in the trem claw by a quarter turn and I raised the action just a little bit. No problem.
Old 08-26-2008, 03:21 AM
Thanks for the replies everyone. Just thought I'd ask before going ahead and doing it!
Kaizzen: Doesn't the EP already have 5 spring holes? :S
Cheers
'87
Old 08-26-2008, 08:29 PM
kaizzen  is offline
Both mine only have 3..... There is two other holes but they are clamped down with the 2 screws and a plate locking the springs in.......
If anyone can give me some more info that would be great...
Old 09-19-2008, 02:25 AM
frankthetank  is offline
Posts: 6  -  iTrader: (0)
I would recommend using 4 springs if you can with 10's. It's easier to bend and sustains slightly better. You need a bit more pressure to use the tremolo but it's still much better with 4 springs imo.
Old 09-20-2008, 05:19 PM
Foulacy  is offline
Posts: 354  -  iTrader: (0)
I use 3 springs with 10's and 2 springs with 9's. but that's just me!
Old 09-21-2008, 04:07 AM
TheToneZone  is offline
Posts: 209  -  iTrader: (0)
you might have to tune up the intonation a bit too, which is a pain in the a$$. i'm thinking of changing to 10's myself for a bit more authoritau...
Old 09-24-2008, 04:48 PM
Foulacy  is offline
dude, 10's give it to you.
Changing string gauges on a non Floyd Rose guitar Technetium Tech: Setup, Repairs and Mods 5 05-01-2008 02:25 PM
I was thinking of changing my guitar from H-S-H to H-H-H... Please give your thoughts Avenite Tech: Setup, Repairs and Mods 12 12-18-2007 06:26 AM
Changing String Gauges... count_dissident Tech: Setup, Repairs and Mods 2 12-03-2006 12:10 AM
Thinking about changing wiring scheme on K7 ajdehoogh Tech: Setup, Repairs and Mods 1 02-08-2005 06:41 PM
Changing string gauges - What's to be setup again ? Wicked Blade Tech: Setup, Repairs and Mods 2 04-22-2001 02:21 PM
