Tips for Peavey XXX Hiss ?? - Jemsite
Old 02-21-2006, 02:03 PM
ric232  is offline
Posts: 82  -  iTrader: (0)
I just got one of the Peavey Triple XXX Super 40EFX's on blow-out from MF. Seems pretty good, but I'm still checking it out. My current amp is a Vox AD50VT, which sounds pretty darn good except that it is too dark (muddy actually) on all settings except clean.
Anyway, the XXX has quite a hiss at idle. The hiss I'm talking about is not affected by which channel I'm using or the gain or volume settings. (Cranking up the volume on the Ultra channel actually introduces a separate hiss, but I'll never have the volume cranked up that much so it won't matter.) I picked up a MXR SmartGate and it definitely helps w/o affecting tone (at least to my ears). I put it on either the HISS or MID setting with the trigger knob turned all the way down and it is very transparent.
Do you guys think I've taken the best approach to reduce the hiss or would you have done something different? (Let me go ahead and give the first answer that I know is coming: "Yeah, I would have bought a better amp")
Thanks in advance for the advice.
Old 02-21-2006, 03:46 PM
john1880  is offline
Posts: 469  -  iTrader: (1)
Re: Tips for Peavey XXX Hiss ??
That sounds like it's working great for you. I have a 5150 and that thing hisses too.
Old 02-21-2006, 06:02 PM
nightfiend14  is offline
Posts: 1,007  -  iTrader: (10)
just would like to say I am fond of the MXR smartgate too and think it's great. Sounds like it should work fine for you.
Old 02-21-2006, 06:51 PM
ric232  is offline
Regarding the MXR Smartgate, is the battery being drained when the stomp switch is off if I leave the plugs in both the input and output?
Old 02-22-2006, 06:07 AM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
can always get one of these done to it
http://www.voodooamps.com/standardmods-peavey.html#xxx
peavey triple xxx
Hiss with pedal in front of amp, not in fx loop? fwd0120 Gear and Equipment 33 08-15-2013 12:48 PM
Crunch Lab 7/Liquifire 7 Hiss - Normal? webmaestro Pickups & wiring 3 02-07-2013 06:53 PM
tone control and hiss xklusivly4u J-Custom, USA Custom & Prestige Ibanez Guitars 6 05-08-2007 05:46 PM
Tube Amp bussy hiss Al M Gear and Equipment 5 11-19-2005 10:16 PM
Peavey Rockmaster tips! Jupiter Gear and Equipment 0 01-25-2004 02:36 AM
Powered by
