Old 12-08-2006, 05:51 PM
jm1681  is offline
Posts: 316  -  iTrader: (0)
Toggle switchable volume cut?
Can a toggle switch be used to lower output volume? Not necessarily kill it altogether, but maybe lower it 1/2 way or more?
Basically, I'd like to be able to flick a switch and go from dirty to slightly dirty clean.
Old 12-08-2006, 05:58 PM
ibanez2005  is offline
Posts: 910  -  iTrader: (0)
Re: Toggle switchable volume cut?
Put a switch and a resistor in line with the output jack.
Old 12-08-2006, 10:26 PM
ChopTart  is offline
Posts: 1,390  -  iTrader: (1)
If you use a LP or similar 4 control guitar where a volume is wired to individual pups, you can set the volume and use the pickup selector to kill or dampen depending on how much. Just don't do it too much, because rapid selection with the switch overtime will overheat it and ruin it. Easy enough to replace though.
Old 12-08-2006, 10:30 PM
jm1681  is offline
Thats along the lines of what I was thinking.
What kind of resistor should I use?
Old 12-08-2006, 10:31 PM
elcid  is offline
Posts: 8,719  -  iTrader: (12)
I never heard about it overheating like that, how does that work? (Im nhot being sarcastic here, Im being serious, after installing a bunch in my LPs I dont see how it would overheat)
Old 12-08-2006, 10:32 PM
C.Thep  is offline
Posts: 3,050  -  iTrader: (18)
friction? jk
Old 12-08-2006, 10:36 PM
elcid  is offline
no, that wouldnt do it
ChopTart  is offline
It was in some article I was reading about creating that stutter effect that said that the switch for the pups wasn't meant to take that kind of abuse for extended periods and gets messed up from the heat generated by quickly switching back and forth. Dunno if it's true, but it makes sense to me.
Old 12-08-2006, 10:45 PM
elcid  is offline
no it doesnt, the thing that makes and breaks the connections doesnt really rub on anything. I can see the switch going bad because the part it pivots on wearing out, but not overheating
Old 12-09-2006, 12:10 AM
ChopTart  is offline
That's probably it then.
Old 12-09-2006, 06:46 AM
Find out the value of the pots on your guitar, probly 250K or 500K and get a resistor thats half the value.
Or try rolling off the volume to where you'd like the volume to cut down to when you switch and if its about 33% down then get a resistor thats a third of the value of your pot. Might be worth buying a few different value ones anyway just to see which you prefer, they dont cost alot anyway.
Old 12-09-2006, 09:40 AM
jm1681  is offline
Thats what I was looking for, thank you
Should a capacitor find its way into the mix somehow as well?
Old 12-09-2006, 12:21 PM
Not really, a capacitor will only create a low pass filter. If this is what you want, there is a formula to work out the values and mathematics of it, its complex though.
Old 12-09-2006, 01:16 PM
Racerx2k  is offline
Posts: 1,076  -  iTrader: (0)
I'd pose that question to Tom Morello. He tends to abuse the toggle switch!
Old 12-09-2006, 01:39 PM
Overheating, seriously? Man you would need some seriously powerful pickups to overheat a switch. Dont listen to that Jm1861, a switch and resistor is the way to go.
toggle switch, tom morello
Swapping toggle switch and volume pot? ShredHead42 Tech: Setup, Repairs and Mods 2 08-08-2006 11:01 PM
Effects loop volume drop in Prosonic sanchez Gear and Equipment 3 05-31-2005 09:06 PM
HELP! Volume pot problem on my js1000btb. Vaislittlefinger JS (Satriani Model) Ibanez Guitars 5 03-03-2005 09:26 PM
Wire a Toggle instead of a Volume pot? MagicAxe Pickups & wiring 4 05-27-2004 12:48 PM
Volume pedal for Solo boost Dan D Mahnn Gear and Equipment 7 06-21-2003 02:03 PM
