Old 06-19-2009, 07:38 AM
prydogga  is offline
Posts: 942  -  iTrader: (0)
Reviews: 4
Top mount Trem
What type of routing is needed to put an OFR or Edge on a traditional style tremolo rout for an EVH type dive bomb only setup?
Old 06-29-2009, 01:13 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Re: Top mount Trem
This depends totally on the neck angle and string height above the body. ON the early Kramers, the floyd Rose bridge fit in what looked to be standard Strat routing. Later on, the recessed versions were done for 2 reasons. 1-so you could have lots of pull UP(which you say you don't want) and 2-so the strings could be closer to the body(less neck angle). If you have a bolt-on neck, you can adjust the angle with shims, or by shaving the bottom of the pocket to a slight angle. If you sit an Edge or FR bridge in the routing you have, you can measure the height of the saddle(and add 1/16 to 1/8") and see if it will work(measure the height you have with the old bridge first). BTW, the 1/8" is to allow the front edge to pivot and not hit the body.
FT: F2 and F4 direct mount finstah Classified Ads: Guitars and Gear 0 01-16-2009 12:10 PM
From pickguard mount to body mount vaisteen2003 J-Custom, USA Custom & Prestige Ibanez Guitars 5 06-21-2007 03:13 PM
replacing a rear mount nut with a front mount one Koss Tech: Setup, Repairs and Mods 3 08-31-2005 01:56 AM
Edge trem arm, with floyd mount? sepsis311 Tech: Setup, Repairs and Mods 0 05-18-2005 12:15 AM
Problem with Trem Post 'mount' dysfctn Tech: Setup, Repairs and Mods 9 09-22-2004 04:05 AM
