Tech: Setup, Repairs and Mods
Transforming 6 string into baritone
07-28-2004, 05:17 AM
akinu
Posts: 31 - iTrader: (
I got an Ibanez EDR-470x (and I thought it would be nice to transform it into a
baritone guitar
(B-E-A-D-F#-B). However, although I adjusted the
truss rod
and spring configuration accordingly, the guitar is still going out of tune easily. I first used 0.08 and then 0.09 strings to see if the thin strings lose their tension quickly in lower tunings. The result is the same;
1-The strings go out of tune when I use the whammy bar or after extended playing
2-Despite I adjusted the truss rod, the tune on the first fret and 12nd fret is significantly different.
Any suggestions on how to get this right?
akinu
Find all posts by akinu
07-28-2004, 05:32 AM
dex
Posts: 1,972 - iTrader: (
First of all you can't "transform" a normal guitar into a baritone just by adjusting the truss rod - baritones have longer scale lenght.
Second - if you want to downtune you need thicker strings, not thinner.
13-60 or at least 12-56
gauge strings
will give you way more stable tuning.
After doing all this you will need to intonate your guitar so all the frets are in tune.
ilia
dex
Find all posts by dex
07-28-2004, 10:30 AM
darren wilson
Posts: 4,190 - iTrader: (
dex
Incorrect. Musically speaking, "baritone" is a note range between tenor and bass. You
can
tune a standard-scale guitar to that range, it's just not ideal without a lot of tweaking.
The reason most baritone instruments have a longer scale length is because lower notes have a longer wavelength, and the longer scale length and heavier strings help the notes to ring more clearly and intonate properly.
The scale length is not the defining factor for an instrument being a "baritone". The tuning is.
But you're right about the
string gauges
. At 25.5" scale, you're going to want the heaviest strings possible to tune down to B. Lighter gauges will get knocked out of tune if you look at them wrong.
darren wilson
07-28-2004, 12:32 PM
dex
Nitpicking.
Can you tune down any guitar - yes.
Can you transform any guitar into a baritone - only by changing the neck for a long scale one.
By deffinition in the guitar world a "baritone" is a longer scale instrument.
You know I'm right.
ilia
dex
07-28-2004, 02:06 PM
Drew
Posts: 4,538 - iTrader: (
dex
You know I'm right.
by
colloquial
definition, a baritone has an extended scale length. Literally, "baritone" refers to the pitches, not the scale length.
Analness aside
, goign for lighter strings is the LAST thing you want to do when detuning. Try a set of 11's tuned B-B; this ought to get you into approximately the same
string tension
you're used to on a standard-tuned six.
-D
Drew
Visit Drew's homepage!
Find all posts by Drew
07-28-2004, 02:19 PM
dex
dex
By deffinition
in the guitar world
You know I'm right.
I'm sorry guys but this is NOT a singing forum - it's a GUITAR forum.
Do you really need to be this anal???
When was the last time I posted something that was complete and utter rubbish to warrant a "Deffinition of pitch for the slow" lesson???
ilia
dex
07-28-2004, 02:22 PM
Algiman
Posts: 2,553 - iTrader: (
Whoa, hit a nerve there Dex!
Standard tuned guitars have a variety of
scale lengths
, as do bass guitars, so baritones could be just as hard to define. Works far better with the longer scale neck though.
Algiman
Find all posts by Algiman
07-28-2004, 02:29 PM
dex
You tell a million guitarists "baritone" - all 1 million will think "longer scale lenght"
You tell the same million "downtune" - 999 999 of them will think "tuning down a normal guitar"
As I said a few times - you know I'm right and all you guys are doing is nitpicking.
As simple as that.
ilia
dex
07-28-2004, 02:38 PM
darren wilson
Just because 999,999 people are mis-informed, that doesn't make them right.
darren wilson
07-28-2004, 02:52 PM
dex
Are you telling me that when you hear "baritone" in reference to a guitar, you imagine a normal 25.5" guitar tuned down or at least 27" guitar tuned down???
Comunication breakdown.
akinu - disregard our bikering and get yourself a set of 12-56 strings.
After changing them, google "guitar intonation" and do it and for future reference - what you want to do is downtune your guitar, not transform it into a baritone.
ilia
dex
07-28-2004, 03:21 PM
The Euphor
Posts: 2,948 - iTrader: (
Interesting.
"Wow dude! Did you use a baritonguitar to record that song?"
"Uhm... I don't know. We played in the dark..."
Another thought. Would a sevenstring guitar be concidered a bariton? Does it have too many strings? Too short neck?
Could a uptuned sixstring bass be a bariton? Or would it's scale be too long?
Take your pills!
The Euphor
Find all posts by The Euphor
07-28-2004, 05:36 PM
akinu
Lol, the discussion is going really interesting. Thanks for all the replies.
Dex- What I meant by "transforming" is actually downtuning.
I first tried my usual thinnest strings 0.8 and then saw that they didnt work, tried one bit thicker which is 0.9. Now I see that 0.9 is not enought too.
Guess I will leave the baritone thingy altogether. It sounds great but it is useless until you find a 5 string bassist or a similar tuned bass player.
Next 10 point question: This EDR is my new guitar, so (as I am also new to
electric guitar
tech) I am recently getting to know my instrument better. Is there any way I can figure out whether this tuning problem stems from the improper construction or setup of the guitar (bad construction of the neck or the bridge)?..
akinu
07-28-2004, 06:25 PM
dex
We're all crazy.
Sounds like you're not stretching your strings.
After changing the strings you'll have to be patient and tune the guitar up while stretching the strings.
Keep the nut unlocked for 2-3 days and keep retuning every time you need to.
After 2-3 days just adjust all fine tuners even and in the middle and lock the nut.
Fine tune and you should be in business.
For more details go here
ilia
dex
07-28-2004, 06:57 PM
darren wilson
With all due respect, it shouldn't take 2-3 days for your strings to settle in. If you properly stretch new strings as you're putting them on, there's no reason why your tuning shouldn't be stable by the time you've finished the whole operation. With practice, you should be able to do the whole string change in well under an hour.
darren wilson
07-28-2004, 07:44 PM
akinu
dex
We're all crazy.
ilia
Thanks dex.. Now the last (hopefully hehe) question. I dont like playing with heavy gauges, so I decided to tune up a bit so I tuned every string half interval up. So from B to B tuning, I tried C to C tuning and now everything seems perfect. Strings stay in tune and inter-fret tuning is reasonable.
The problem is, despite the spring tension is screwed to maximum, the
bridge angle
is a bit high and thus the action is high. As the springs are at maximum strech, I cant screw it more. What can I do to lower the action?
akinu
baritone guitar
bridge angle
electric guitar
floating trems
gauge strings
guitar tech
pro edge
scale lengths
string bass
string gauges
string tension
truss rod
convert 7 string to 6 string?
where to buy guitar string sin southampton
what distortion pedal can take guitars string 10-60
use a .016 for the 2nd string?
jpx 7 string?
01:16 AM
