Tech: Setup, Repairs and Mods
Trem angle changed after changing strings!
06-13-2008, 01:02 AM
badguitarist
Posts: 61 - iTrader: (
I've searched the forum for half an hour but couldn't find any threads really relevant to my problem.
I changed my strings on my RG1570, Edge Pro trem. Same gauge and brand as before (10-46, EB). But after restringing and tuning strings to pitch the trem angle went positive. I know how to adjust the trem angle and it should be fine. But my question is how did my trem angle change? How can I get rid of that next time so I won't need to adjust the trem angle again? I changed the strings one by one and did not block the trem. Thanks for any replies mates!
06:51 AM
badguitarist
Find all posts by badguitarist
06-13-2008, 06:17 AM
AleTheNervo
Posts: 459 - iTrader: (
Re: Trem angle changed after changing strings!
Maybe you only need to stretch them better
AleTheNervo
Visit AleTheNervo's homepage!
Find all posts by AleTheNervo
06-13-2008, 06:49 AM
badguitarist
AleTheNervo
Nah, I think strings get lack after stretched so we must tune it up. That makes the angle even more positive, doesn't that?
badguitarist
06-13-2008, 07:35 AM
AleTheNervo
so you inted the trem went backwards...sometimes you could buy a set of string which is already old or isn't perfect, I wouldn't worry about it, maybe fix the issue setting the springs or change the strings
AleTheNervo
06-13-2008, 07:45 AM
jemaholic
Posts: 2,806 - iTrader: (
Sounds like one of the strings in the new set is a different gauge than it's supposed to be.
jemaholic
Visit jemaholic's homepage!
Find all posts by jemaholic
06-13-2008, 09:00 AM
badguitarist
No way mates. The strings were dead new, shine as sun. And I don't think there was a string with a wrong gauge. Have any of you had the same problem before?
badguitarist
06-13-2008, 09:42 AM
JJEMMER777
Posts: 8,374 - iTrader: (
It's a common occurrence and is not a big deal. A quick adjustment to the spring hook screws should solve the problem straightaway
JJEMMER777
Find all posts by JJEMMER777
06-13-2008, 10:38 AM
Posts: 19,352 - iTrader: (
Stretched strings become thinner which makes the gauge smaller.
06-13-2008, 10:59 AM
badguitarist
JJEMMER777
But it's always better if you don't need to do this and everything is ready to go, right?
Then the new strings should be the same as old strings for they're all streched by me, shouldn't they? So they're all the same in the end of the day and should make no difference huh?!
badguitarist
06-13-2008, 11:06 AM
Old played strings are stretched even further.
06-13-2008, 11:13 AM
JJEMMER777
badguitarist
Well sure, but just as old played strings stretch, old ~springs~ begin to stretch after time as well and eventually a slight adjustment is basically unavoidable
So just DO IT and ROCK~~~
BTWW - Also keep in mind that you'll need to periodocally adjust the truss as well
JJEMMER777
06-13-2008, 12:26 PM
badguitarist
JJEMMER777
What's it for?
badguitarist
06-14-2008, 07:18 AM
AleTheNervo
It's to control the
neck bow
AleTheNervo
06-14-2008, 08:07 AM
badguitarist
AleTheNervo
It's to control the neck bow
But why periodically?
badguitarist
06-14-2008, 08:11 AM
AleTheNervo
because the humidity, temperature ecc. variations cause the wood tho change its setting
AleTheNervo
neck bow
how to change strings on js 1200
how to intonate a zr trem
what trem is on the rusty cooley
what kind of strings does korn use
how much can a guitar's tone be changed by pickups?
Having problems with trem angle...
Adagio_777
06:33 AM
re: Floating Trem angle (w/pics)
Daryl
09:58 PM
Trem angle
B1Zzar3
11:36 AM
About intonation and trem angle
Yō_Kun
03:55 AM
Changing pickups....what to do with trem?
jclogston
Pickups & wiring
05:01 AM
07:41 AM
