Old 02-25-2007, 05:17 PM
AMD1014  is offline
Posts: 178  -  iTrader: (0)
Trem angle issue
Hi guys i was setting up the angle of my trem and one side is lower than the other, what should i do??
Old 02-25-2007, 06:04 PM
Satchriossi  is offline
Posts: 294  -  iTrader: (1)
Re: Trem angle issue
Get an allen key (hex wrench) to fit the trem posts and turn them to get the height balanced. Clockwise lowers the post. I don't recommend doing this with tension on the strings as it will grind down your knife edges and posts - you should grease these contact points with heavy bearing grease if possible - it will make them last much longer.
Old 02-25-2007, 06:08 PM
AMD1014  is offline
Thanks, where are the contact points located?
Old 02-26-2007, 04:34 PM
Where the knife edges meet the trem posts and where the strings touch the saddles - grease these to help tuning stability and reduce wear.
lo -pro trem angle jem_fanatic Tech: Setup, Repairs and Mods 8 06-23-2006 10:49 AM
Changed brand of strings - same gauge: trem prob - help! tim505 Tech: Setup, Repairs and Mods 7 01-02-2004 02:08 PM
Trem angle wangbar Tech: Setup, Repairs and Mods 8 11-25-2003 06:37 PM
10 gauge strings and trem angle... chilln2music Tech: Setup, Repairs and Mods 3 08-28-2003 03:18 AM
Can't get edge trem in adjustment - always too high, too low bduersch Tech: Setup, Repairs and Mods 4 11-19-2001 12:37 AM
