Old 04-28-2002, 03:04 AM
Theater of Dreams  is offline
Posts: 1  -  iTrader: (0)
Trem height and action problem. - Lowest possible trem heigh
Hi everyone.
I have a jem 555 and have recently changed the trem to an Edge.
Problem is that even when set at the lowest possible trem height.. the action is very high at approx half a centimeter.
Is there anyway to fix this?
Thanks
Old 04-28-2002, 03:45 AM
CrossingStar  is offline
Posts: 1,046  -  iTrader: (1)
Shimming the neck is the first thing that comes to my mind.
Old 04-29-2002, 03:45 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
check for the neck straightness. if it's good (straight, or with a little little little relief), do what Xing said: put a shim on the neck-body joint, in order to have it slightly bent downward.
a question:
did you replace the posts too? if you put the Edge's in TRS posts instead, check for the Stud Locks to be loosen [size=0.5](loosened? sp?)[/size]
if you need some further help, mail me -m-@libero.it
trem height
