Ive read almost all of the setup articles and im a little bit puzzled as to what to do with my
neck angle. going off of the setup articles it says to do this:
Bridge sits too low into the body when trying to get good action - increase the neck angle by shimming the headstock side of the
neck joint. This allows you to raise the bridge and lower the action simultaneously. Reattach the neck and raise the bridge to test
my pivot posts ( locking, with a regular ibanez edge ) are screwed all the way down. my action is still fairly high. but wont adding a shim to the neck side of the pocket raise the nut and also the action along the entire neck ? i thought id ask just to get a yay or nay before i take it apart and give it a shot. the guitar is a jem ive been putting together from different pieces i find on the bay. thanks in advance for the help
