Old 08-16-2006, 01:32 AM
ihateemokids666  is offline
Posts: 13  -  iTrader: (0)
Trem Help
Alright, I had my a set of 12-56s on my guitar, and they were getting old, so I decided to get new strings. My friend also called that day as was all "Lets start a band nigjew and use Drop D." So, I bought strings today, figured 10-52s would be light enough for Drop D, but boy...
As I began to string my guitar, the dull light shined upon my flamed Turqoise burst finish, making it look ever so radiant. I started to loosen the strings (starting with the low E, and as I loosened it, 3 of the strings broke, and I was left with two strings on. The string tension had become so great because the trem had recessed, that I had to loosen those too, before they snapped.
Then, I tried to start again.
E, e, A, B, D, G, to try and raise the trem evenly.
But then, once I had gotten the strings on and tried to tune, things starting sucking, like an Oreck XL (The ones that can pick up the bowling balls). I can't tune up any higher than B before the string tension gets uber hella tight. So I loosened the trem to try and give it a little slack, and tried again. Same problem. Now I've got my guitar in B standard, with the trem at like a 35 degree angle, and the springs about 2 inches from being flush from the wood.
As far as I remember B standard =/= Drop D.
Help.
Old 08-16-2006, 01:52 AM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Re: Trem Help
Old 08-16-2006, 01:56 AM
Re: Trem Help
Yeah, I know how to set it up, thanks. But, there shouldn't be this much tension, this low a tuning, with this light of strings.
Old 08-16-2006, 02:03 AM
john1880  is offline
Posts: 468  -  iTrader: (1)
Re: Trem Help
how many springs you got in there? if you have 4, pop one out.
john
Old 08-16-2006, 02:06 AM
Dee  is offline
Re: Trem Help
No offense but I'd say there's one or two things you might have overlooked.
Old 08-16-2006, 02:08 AM
Re: Trem Help
Springs are like they were when I bought it
Joshisnumber3 (assuming that is his name over here) said:
Originally Posted by joshisnumber3
Chaz, as far as I know, it would be beneficial for you to have your springs setup in the method I stated (According to what my Ibanez Prestiege and what some people have said on jemsite, it's best to keep it one spring in the middle and then one on each side.), but I would really suggest bringing this over to jemsite or summat.
Dee: care to help then?
string tension
Replacement of your trem arm - "tutorial" with pictures Jammy Tech: Setup, Repairs and Mods 93 05-16-2009 06:56 AM
setting the trem angle...questions atarilovesyou Tech: Setup, Repairs and Mods 2 03-07-2006 04:39 AM
Trem angle wangbar Tech: Setup, Repairs and Mods 8 11-25-2003 06:37 PM
UV Trem plate changeout - Encountered a glitch. bob oakman Tech: Setup, Repairs and Mods 4 04-02-2002 05:15 PM
Repairing trem knife edges - Trem on my JS1000 will not retu Jason Stone Archived Topics and Common Questions - GO HERE FIRST 2 01-01-2001 09:24 PM
