Old 05-20-2007, 08:16 AM
0americana  is offline
Posts: 109  -  iTrader: (0)
Angry
Trem-low, my trem is still too high!!
I have posted a thread about this before, got some answers, tried them out and the havent worked.
My trem claw is screwed all the way in it has 5 springs on it and its still to high!!!
im only using 10'sand i cant seem to slove this at all. someone please help.
Old 05-20-2007, 08:21 AM
madpickin03  is offline
Posts: 531  -  iTrader: (1)
Re: Trem-low, my trem is still too high!!
get some newer springs, the old ones are probably overstretched
Old 05-20-2007, 08:25 AM
they're brand new.
Old 05-20-2007, 08:28 AM
whoa... 10-46 or 10-52? What tuning?
Old 05-20-2007, 01:33 PM
10-46 standard
its blaggin my head so much coz i have his on all my other Rgs and there all fine with 3 springs
Old 05-20-2007, 01:40 PM
S-man  is offline
Posts: 1,757  -  iTrader: (0)
Sometimes the trem gets in a wierd position were it won't level out. Try loosening all the strings and retune.
Even better, block the trem, tune, then remove the block.
5 springs is a little ridiculous IMO.
Old 05-20-2007, 03:06 PM
RG462  is offline
Posts: 507  -  iTrader: (0)
yeah, it seems like your strings are too tight, your spring tension and string tension isn't balanced out. The best to do it would be to block the trem and tune.
Old 05-20-2007, 03:22 PM
Reeto, well the trem is blocked at the moment so ill put on a fresh set of strings and see what effect that has.
Old 05-20-2007, 03:34 PM
S-man  is offline
When you get it tuned, adjust the claw so you can remove the block without messing up the tuning dramatically and that should get you pretty close.
Old 05-20-2007, 04:05 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
5 springs with 10's? Are you sure you're not tuned an octave too high!? LOL. 3 springs is about normal if they're screwed all the way in.
Old 05-20-2007, 05:26 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Smile
Post some pictures of the claw, the trem and the height of the strings and let us see what you're talking about. 5 springs is overkill IMO, especially for an Ibanez.
Jimmy
Old 05-20-2007, 09:59 PM
buddroyce  is offline
Are your new springs long springs or short springs?
Old 05-22-2007, 04:41 PM
well ive had some debate over that because i started with 3 all the same, someone suggest putting in more spring went ot this store and got 2 extra but they dont seem to be tensed as much as the orginal 3.
so i think i could be the springs.
Old 05-22-2007, 06:43 PM
newbieguitarmaker  is offline
Posts: 4,030  -  iTrader: (5)
Images: 1
get new springs from Rich, 3 should do fine if you get them from him. I believe
Old 05-23-2007, 12:05 AM
S-man  is offline
Put the original 3 back in ..
Post pics.
cavity cover, guitar tech, spring cavity, string tension, trem claw
Modding an S270's trem AirGuitarHero Tech: Setup, Repairs and Mods 6 07-21-2004 09:45 PM
UV Trem plate changeout - Encountered a glitch. bob oakman Tech: Setup, Repairs and Mods 4 04-02-2002 05:15 PM
Problem with adjusting trem - is it possible to damage the a Soloist Tech: Setup, Repairs and Mods 2 02-26-2002 02:17 PM
Lower Gauge Strings or More Springs? - Dodgy Trem Behaviour grrrpoop Tech: Setup, Repairs and Mods 13 08-08-2001 12:29 AM
Ibanez RG with hardtail? - high quality RG with no trem?? shask Other Ibanez Guitars (including Premiums) 11 04-09-2001 11:16 PM
