Old 05-21-2008, 08:01 AM
Crazy_Guitar  is offline
Posts: 1,319  -  iTrader: (0)
Reviews: 4
Trem Post mod
Hey there!
I didn't find this info here.
Is there anyone that made a step-by-step guide on how to replace the new trem posts for the good-old locking trem posts?
I read the tutorial on Rich's www.ibanezrules.com, but it's still very blurry to me.
Anyone, please?
Old 05-21-2008, 09:11 AM
axemanrio  is offline
Posts: 992  -  iTrader: (13)
Re: Trem Post mod
I installed the mod recently and it's perfect. If you can tell me which part of Rich's instructions are blurry, I'll try to help out
Old 05-26-2008, 02:01 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Re: Trem Post mod
If you get locking studs, you're halfway there. If you cut the paint around the inserts(so you don't chip the heck out of it) and pull the inserts(I use an old stud and a claw hammer with a piece of wood to protect the guitar face), then take standard roofing nails(large heads) and dremel the head off and grind the nub flat. Drop these in the holes and press the inserts back in. This has worked great on 2 guitars for me(had Edge Pro with non-locking studs).
Old 05-31-2008, 05:25 AM
wandereruk05  is offline
Posts: 303  -  iTrader: (5)
Re: Trem Post mod
do these make that much of a difference? i'm getting a js1000 soon and installing a tremol-no (mainly for easy of tuning/string changes) so would the mods make a huge difference?
Old 05-31-2008, 05:41 AM
Re: Trem Post mod
Yes, I have seen a noticeable difference - but it's a combination of things that helps alleviate tuning stability issues. Read up more on Ibanez Rules.
I don't see how a tremol-no could substitute locking studs, so get the locking studs even if you don't add the tremol-no.
locking stud, locking studs
Trem post inserts - What is the diameter? bammbamm Tech: Setup, Repairs and Mods 4 03-11-2008 01:08 PM
RG570, loose trem post stud insert leclaw Other Ibanez Guitars (including Premiums) 0 02-18-2006 10:46 PM
Need an ibanez trem post j.arledge Classified Ads: Guitars and Gear 3 11-24-2005 12:27 AM
can't take out a broken trem post, advice? j.arledge Tech: Setup, Repairs and Mods 9 11-15-2005 08:05 PM
Question about trem post - How tight loose? Triangle Tech: Setup, Repairs and Mods 6 08-08-2001 04:50 PM
