Old 12-08-2006, 12:12 PM
leec  is offline
Posts: 161  -  iTrader: (4)
Trem problem: sharp and flat
I've just bought a 7620 and when it arrived, it all needed a good clean up and set-up.
I popped the trem off so I could give the guitar a clean. I didn't use the trem before doing this, so I don't know if this problem existed before I popped the trem, but I'm guessing it must have:
If I pull up on the bar and then let it return to neutral, most of the strings go sharp by quite an alarming amount. Then if I dive and let it return, they're flat by the same amount. Neutral position isn't neutral; it depends upon whether I dive or pull before letting it return.
I took a look at the knife-edges, they seem nice and sharp still. The whole guitar is in amazingly good condition, hardly used, so I doubted it'd be that.
The trem seems to be sat nicely into the grooves on the posts. I also locked the posts, too (they weren't locked) and matched their height before doing so.
Does anyone have any ideas about what could be causing this?
Old 12-08-2006, 01:27 PM
Demiurge  is offline
Posts: 883  -  iTrader: (7)
Re: Trem problem: sharp and flat
Did you pre-stretch your strings? (well, that wouldn't explain them going sharp, would it!) How well do you have the nut locked? The strings could be binding up in the nut if it's not tightened enough.
I don't do it myself, so I'm sure about the particulars, but please someone else chime in to correct me: that trick with the lim balm, do you put it on the trem posts at the point of articulation with the knife edges? I think that's the case, because even though the knife edges are sharp, too much friction may cause binding at that point. Are the posts themselves in good shape?
Old 12-08-2006, 03:15 PM
leec  is offline
Aye, the nut's clamped down tightly, and I doubt it's the strings stretching.
I didn't know the trick with lip balm. I'll have to get some and try it.
I checked everything out just now, and everything seems to be in great condition; it's barely been used. This is very frustrating. I'm not particularly great with setting up guitars, so I'm probably missing something easily fixed, but I can't see what's causing this problem.
Old 12-08-2006, 03:34 PM
Chroma  is offline
Posts: 96  -  iTrader: (0)
I had a Dean 7 string with a problem that seems just like this.
I bought it used, had the same problem you described and when I asked some more question about it and why there was no bar for the floyd...I was told by a friend of the original owner the guitar had been knocked face first off a stand which snapped the bar in half when it landed.
I took the floyd completely off and looked closely at the knife edges. On the treble side, exactly where the post met the pivot point, the edge had been flattened. It basically functioned like two different knife edges on that side of the floyd and depending on which way the bridge was moved, one of the two would seat in the post.
Old 12-08-2006, 04:20 PM
leec  is offline
I was checking on Rich Harris's very comprehensive site and this site for tips. It looks like my knife edges are within normal parameters.
I also checked the posts, and they look to be in ok order.
Old 12-08-2006, 05:16 PM
Rich  is offline
Posts: 19,350  -  iTrader: (21)
You might have missed a page
http://www.ibanezrules.com/tech/setu..._stability.htm
Old 12-08-2006, 10:16 PM
leec  is offline
I did check that page, but missed the one thing that seems to have fixed it: 5. Loose Nut. I didn't read this paragraph, I'd assumed it meant the nut clamps. Stupid me.
Thanks a lot, Rich; between your advice and your site, it seems ok. Thanks to everyone who replied, too.
I'd say the trem now functions at a 93-95%. I think maybe some of this Chapstick lip balm might help push it up a bit. Does it have to be this Chapstick brand? Or can it be any of the waxy "lip-stick" like ones?
Does it have to be a certain flavour?
Old 12-08-2006, 10:22 PM
Rich  is offline
#3 - procedure seems to be one of the least understood also.
Any PTFE impregnated lubricant will be as effective. Contrary to all Kevin's rants on it's superiority I tested it against Chapstick and it was absolutely no better or no worse, they were even, Chapstick being a lot easier to find and a lot cheaper, in the US anyway
Old 12-08-2006, 10:33 PM
OLIE_ROCKS_THE_80'S  is offline
Posts: 2,770  -  iTrader: (5)
Reviews: 10
Lightbulb
Originally Posted by Rich View Post
Hey Rich you should make a "How to set up your guitar video" with the amount of knowledge you have, it would be extremely useful and I bet tons of guys would buy it!!!
Old 12-09-2006, 12:53 AM
Rich  is offline
I have a hard enough time just writing pages. I'm finally writing the truss rod page for all these guys that don't wear pants
Old 12-09-2006, 02:05 AM
Lefty Robb  is offline
Thats a bomb Idea...Don't forget Rich, you could upload them all to Youtube so you wouldn't have to use or pay for any bandwidth...
Old 12-09-2006, 02:15 AM
Rich  is offline
The first tech page I've written in a year
http://www.ibanezrules.com/tech/setup/truss.htm
Yea, I'll get right on the video
Old 12-09-2006, 06:38 AM
chlamy  is offline
Posts: 283  -  iTrader: (0)
I actually second the video idea ! I know that Rich, you might have way more things to do every day then eventually doing a video, but I have seen this on other websites : a knowledgeable guy makes a cool long pdf or video and makes it available for between 10 and 20 bucks for download on his website. This way you can make some extra cash, and I would be pretty sure that even at 20 bucks there would be alot of people here running to their Visa to buy "Rich's Guitar Setup and Maintenance Course Video"
Old 12-09-2006, 10:26 PM
IbanezGirl  is offline
Posts: 996  -  iTrader: (2)
I reckon a "Rich's Guitar Setup and Maintenance Course DVD" is an excellent idea.
truss rod
How can i make the lo pro edge trem stay in tune? kalashnikov Other Ibanez Guitars (including Premiums) 32 02-01-2006 06:27 AM
Why does tuning go sharp insted of flat? PekkaM Tech: Setup, Repairs and Mods 6 06-28-2003 04:45 PM
Ibanez JPM90HAM Model Problem... - I tried e-mailing them, b Spiral Acid Comments to Ibanez 17 10-04-2001 09:31 AM
Repairing trem knife edges - Trem on my JS1000 will not retu Jason Stone Archived Topics and Common Questions - GO HERE FIRST 2 01-01-2001 09:24 PM
