Old 01-31-2006, 12:30 PM
surfdog777  is offline
Posts: 573  -  iTrader: (4)
Trem pullup on Lo-pro "bottoming out"
I recently lowered the action on my 7v. The action wasn't bad...I just wanted to get it a little lower. Now it seems that the trem won't pull up a 5th like it did before. Can that be corrected with the action where it is now, or am I going to have to raise the bridge again to get the extra pullup?
Thanks
Scott
Old 01-31-2006, 01:35 PM
The Euphor  is offline
Posts: 2,948  -  iTrader: (4)
Re: Trem pullup on Lo-pro "bottoming out"
If I remember correctly, you need to add a neckshim and raise the bridge to get the same low action with more pullup range. I've never done it, just talking from memory.
Old 01-31-2006, 08:26 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Yes, a neck shim will allow the trem to sit higher for the same amount of action. That, in turn, will give you more room for pulling the trem up before bottoming out.
neck shim
Replacement of your trem arm - "tutorial" with pictures Jammy Tech: Setup, Repairs and Mods 93 05-16-2009 06:56 AM
Trem angle wangbar Tech: Setup, Repairs and Mods 8 11-25-2003 06:37 PM
UV Trem plate changeout - Encountered a glitch. bob oakman Tech: Setup, Repairs and Mods 4 04-02-2002 05:15 PM
Can't get edge trem in adjustment - always too high, too low bduersch Tech: Setup, Repairs and Mods 4 11-19-2001 12:37 AM
Repairing trem knife edges - Trem on my JS1000 will not retu Jason Stone Archived Topics and Common Questions - GO HERE FIRST 2 01-01-2001 09:24 PM
