Old 09-28-2009, 08:30 PM
Gio-42  is offline
Posts: 12  -  iTrader: (0)
Trem replacement.
I want to replace my ibanez trem with an original floyd rose trem, but i want it to float by cutting a recess out of it if that makes sence. Any ideas or maybe some blueprints or measurements to do this. i know the bolts to fit the trem to the body fit perfectly, i just want do the rest so it's level witht the body and set it up so it floats, flutters etc etc.
Old 09-29-2009, 05:48 PM
As Hell Broke Loose  is offline
Posts: 58  -  iTrader: (0)
Re: Trem replacement.
In my opinion, the easiest, and most sensible way to do it, since I'm assuming you don't have some professional routing set up, is with a dremel. They sell routering bits at about 4 bucks a pop that make short work of the job, and I think you've got alot more control with the dremel. If you don't have one, a power drill should work fine. You can find routing templates at the floyd rose website.
trem
Best Replacement for Low TRS II Trem? ggl JS (Satriani Model) Ibanez Guitars 15 03-20-2010 12:56 PM
trem replacement CaptainKirk Other Ibanez Guitars (including Premiums) 2 11-20-2008 06:33 PM
Replacement Trem Arm orrlb Tech: Setup, Repairs and Mods 2 02-20-2005 12:08 AM
lo pro trem arm replacement PLEASE HELP! muddeone Tech: Setup, Repairs and Mods 1 08-09-2004 09:42 PM
replacement trem thc303 Tech: Setup, Repairs and Mods 7 03-05-2003 05:20 PM
