Old 04-16-2008, 07:19 AM
dimefan90  is offline
Posts: 234  -  iTrader: (0)
trem to hardtail conversion?
has anyone ever converted a guitar from trem to hardtail. i have looked at the tutorial on project guitar but i will be converting a vintage style trem route.
will the process be any different if so can someone help me out?
Old 04-16-2008, 07:44 AM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
Re: trem to hardtail conversion?
why not just block it or set it so it only dives?
Old 04-16-2008, 08:10 AM
Ibateur  is offline
Posts: 2,947  -  iTrader: (3)
I didn't know that vintage trems actually could pull up. I guess if you tried hard enough...
Anyway, I personally think the hassle of filling the cavity (must behave) too big. If you have a standard strat (you didn't say) maybe you can think about either buying a replacement body or building one yourself. If you have the woodworking skills/tools to create the blocks that would fill the cavities, you probably can build a body with the same skills/tools.
Old 04-16-2008, 09:29 AM
neptoess  is offline
Posts: 303  -  iTrader: (0)
you can do it the same way as on project guitar but i wouldnt route it any more, with a vintage style route you can just use 2 pieces of wood.
Old 04-16-2008, 03:21 PM
wixomwhat  is offline
Posts: 238  -  iTrader: (6)
I just filled in the route on a RG550. Its not really that hard or not as hard as everybody says. Most people that claim it is hard have never even attemped to fill a trem route so dont listen to them.
Old 04-16-2008, 04:37 PM
djohns74  is offline
Posts: 580  -  iTrader: (0)
I transformed an old RG320 body to an RG321 body using that tutorial, mainly just for kicks and a little practice with the router, not because I thought I'd get a great guitar out of it. It wasn't too hard, but you do want to make sure you use decent quality wood. I just used some crap that was sitting around Home Depot, probably pine or something equal awful for a guitar. On the plus side, it was easy to work with and that's about it. The guitar plays fine, but any semblance of tone it ever possessed is gone.
Otherwise, the process went well enough. The thing is, it probably isn't worth the trouble except as an experiment on a cheapo guitar, and isn't worth the risk of ruining the tone of a nice guitar.
Old 04-16-2008, 11:28 PM
i need to do it because im building a pgm replica out of a grg170dx.
Old 04-17-2008, 12:39 AM
ColinMmmmm  is offline
Posts: 1,068  -  iTrader: (1)
You don't need to do anything. Just leave the trem arm off, and block the trem. Get a chrome sticker and put it over the hole the trem arm fits in and noone will know the difference.
Old 04-17-2008, 02:58 AM
this is the replica im making. you can see why i need to do it.
i would like it to be perfect and for me that means no trem cavity in the back.
Old 04-17-2008, 07:21 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
Originally Posted by dimefan90 View Post
this is the replica im making...i would like it to be perfect and for me that means no trem cavity in the back.
right, but that also means you have to strip the body, fill the cavities, sand flush, give a coat a sealer and re-paint it. not what i'd call a quick home job...
Old 04-17-2008, 07:33 AM
Vim Fuego  is offline
Posts: 908  -  iTrader: (2)
Images: 6
Ha! if you look at the bottom right corner of this pic you can see that the first non trem pgm guitar was one with the rem rout filled and a fixed bridge fitted!
So... for the really authentic look you'd have to do as bad a job as that!!
Jim
Old 04-17-2008, 07:45 AM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
To be blunt, the closest you will ever get to perfect will be to get a hard tail body to begin with OR have a professional luthier, with verifiable proven track record, do the work for you. However, for the price of the second you can get the first and it's a lower risk option.
Unless you have the time and skills to do all the work yourself, there's no cheap road to perfection or any semblance there of.
Old 04-17-2008, 08:00 AM
marianozz  is offline
Posts: 2,221  -  iTrader: (20)
Jim
lol that wasnt the 1st.... but yeah, all of Pauls converted hardtails look like crap up close , that 300, the red RG, the Telesavalas...
The 300 even has the standard locking nut with no pads in it
Old 04-17-2008, 08:04 AM
Images: 6
marianozz thanks for the correction, I just assumed you'd bodge it on the first and then do all the others properly!!!
Jim
Old 04-17-2008, 09:54 AM
the rg170 was my best option because i wanted sharktooth inlays and it was cheap.
time doesnt matter and i have some skill. i really like the idea i have, and i really want to see it through. the only problem i have faced is were to get some basswood or maple in my area, as for the difference between vintage and fr style trems, i have decided to route out a bit from the top, just enough to pass the screw holes so that i can fill it in.
fixed bridge, locking nut, sharktooth inlay, sharktooth inlays, trem arm, vintage style trem, vintage trem
Replacement of your trem arm - "tutorial" with pictures Jammy Tech: Setup, Repairs and Mods 93 05-16-2009 06:56 AM
Best Trem Posts LonePhantom Tech: Setup, Repairs and Mods 12 05-02-2008 11:52 AM
Help with Trem Cavity Cover... Shredcows Tech: Setup, Repairs and Mods 6 04-20-2005 08:20 PM
Lower Gauge Strings or More Springs? - Dodgy Trem Behaviour grrrpoop Tech: Setup, Repairs and Mods 13 08-08-2001 12:29 AM
Hardtail conversion for RG5xx models - pros/cons headaches?! woodshed Gear and Equipment 4 04-19-2001 05:55 PM
