Tech: Setup, Repairs and Mods
Truss Rod Problem
03-09-2007, 12:08 AM
waylay00
Posts: 3,763 - iTrader: (
Truss Rod Problem
The other day, as I was doing some routine truss adjustments on my Fender American
Deluxe Strat
, I somehow or another stripped the allen nut at the end of the truss rod. This event is odd, because I always take care when adjusting with truss rods. I barely turned the wrench, and bam, it suddenly lost grip as if it were stripped (VERY odd
)... The truss rod itself is a Fender Bi-Flex rod (similar to the StewMac Hot Rod), so replacing the nut is not an option, since it welded to the rod itself. I've literally tried everything...WD40 (to see if it's a lubrication problem between the threads), all sorts of
allen wrenches
, etc
1) Is there anything I can do to potentially remedy this? I've tried using a 9/64 allen instead of the 1/8 to see if that would work, but it didn't.
2) This neck is dear to me, so replacing it is really out of the option. Yes, I know buying a replacement neck would be cheaper, but this was my first neck...I REALLY wish to keep using it. It means something to me...For replacing truss rods, who are some respectable luthiers whom you would recommend for this type of work?
3) How much would this normally cost to have someone replace the rod?
Thanks,
Wade
waylay00
Find all posts by waylay00
03-09-2007, 12:14 AM
jaxadam
Classified Watchdog
Posts: 3,042 - iTrader: (
Re: Truss Rod Problem
Oh boy... that does not sound good...
I would stop right there, and try to find someone near you who could possibly replace the rod. Being in the heart of guitarland, I'm sure there will be someone around to remedy your problem.
Even then, I'm sure the neck might feel a little different than the original with a replacement rod.
12:22 AM
jaxadam
Find all posts by jaxadam
03-09-2007, 12:22 AM
waylay00
Yeah, this situation really angers me...I am very competent with guitar setups, and something like this should not happen on a $1000 Fender...
waylay00
03-09-2007, 12:23 AM
jaxadam
Classified Watchdog
waylay00
I definitely agree... Best of luck to you on getting that worked out.
jaxadam
03-09-2007, 12:29 AM
waylay00
I'm thinking about coating the
allen wrench
in a release agent, putting a blob of epoxy on the end of the wrench, and letting it sit in the nut. Hopefully, it will fill in the stripped area and the release agent will allow me to safely remove the allen wrench...
waylay00
03-09-2007, 09:03 AM
EL-CeeDee
Posts: 484 - iTrader: (
Sounds like a good solution,.. replacement is the only real solution though.
EL-CeeDee
Find all posts by EL-CeeDee
03-10-2007, 04:15 AM
waylay00
Yeah, I'm thinking of grabbing a replacement neck to temporarily remedy the situation if that doesn't work...
waylay00
03-10-2007, 11:43 AM
Racerx2k
Posts: 1,076 - iTrader: (
waylay00
I'm thinking about coating the allen wrench in a release agent, putting a blob of epoxy on the end of the wrench, and letting it sit in the nut. Hopefully, it will fill in the stripped area and the release agent will allow me to safely remove the allen wrench...
I've had pretty decent results with epoxy putties. They seem to be able to hold up to greater stresses than just epoxy. I once fixed a snapped-off plastic damper control arm, in my old 81' Regal's heating/AC system (switched between the heat and the AC), by re-connecting the 2 pieces together, using that epoxy putty. Held beautifully, even past the day that I sold it. You may be able to control the putty slightly better, too, in the end of the neck. You can just stick it to the end of the wrench, and lower it in, even. Just a thought.
Racerx2k
Find all posts by Racerx2k
03-10-2007, 12:43 PM
ibanez2005
Posts: 910 - iTrader: (
Dont talk to me about £1000 Fenders, the finish on mine has gone crap, no where near the quality i expected.
ibanez2005
Visit ibanez2005's homepage!
Find all posts by ibanez2005
03-10-2007, 02:19 PM
waylay00
Racerx2k
All right, thanks for that. What is a good putty to use for this? Possibly J.B. Weld:
http://jbweld.net/products/jbweld.php
Thanks to all for the help.
waylay00
03-10-2007, 04:38 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
I would try this first...
http://www.stewmac.com/shop/Truss_ro...escue_Kit.html
Jimmy
jb4674
Find all posts by jb4674
03-10-2007, 05:25 PM
Racerx2k
Yikes! Talk about high-priced overkill! I'd still go with the epoxy putty.
Racerx2k
03-10-2007, 10:08 PM
waylay00
jb4674
Jimmy
Can't do that since the nut is welded to the rod itself. Thanks though!
waylay00
03-11-2007, 03:41 AM
ashbass
Posts: 372 - iTrader: (
I'm not familiar with your neck, but from what you describe I'd get a dremel tool and cut a slot across the allen hole so that a large screwdriver blade can fit into it and you can get it out that way. I read in Dan Erlewines' book that that is how he often has to remove frozen/stripped allen screws from old fender
bridge saddles
ashbass
Visit ashbass's homepage!
Find all posts by ashbass
03-11-2007, 03:48 AM
LuredMaul
Posts: 764 - iTrader: (
try the putty first
LuredMaul
Find all posts by LuredMaul
allen wrench
allen wrenches
bridge saddles
dan erlewine
deluxe strat
truss rod
truss rods
how to alter a truss rod
how to adjust truss rod mustang
how to adjust a truss rod on an ec-1000
problem frequencies when mixing
truss rod is loose
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault
leonard deroma
06-18-2007
11:57 AM
Strange problem... possibly with the truss rod?
Bob_The_Moose
06:36 PM
help please, new 1527 truss rod problem i think.
track7
06:25 PM
JCM2000 DSL100 volume swell problem
Joshka
Gear and Equipment
40
04-14-2004
06:49 AM
Truss rod problem
Shredd
01:08 AM
12:33 AM
