Old 01-23-2010, 06:08 PM
Silverburst  is offline
Posts: 586  -  iTrader: (1)
Truss rod screw loose and still not enough bow
This guitar came in this week, and the neck was about straight as an arrow, so I wanted to loosen the truss rod a bit to get some more clearance. I noticed it was already very loose, and when loosening it some more just felt like screwing a screw out with no resistance at all. I prefer 4 springs in the back because it tends to give a more stable tuning so I did add 1 string to the 3-in-arrow that were in. I did get a tiny bit clearance, but not enough to be good. It is stringed with 10-46 and that's what I like as well so I would prefer to keep that gauge.
I made sure it was a loose as it could get and let it rest for a few days, but alas, no extra clearance.
What could I do to gain a little extra bow ? I was thinking of putting extra tension on the neck by screwing the string-plate screw in as far as possible, making the floyd pull, and leave it a few days like that, but my guess was that once I put them back in balancen the neck would restore itself a few days later.
Old 01-26-2010, 04:47 AM
BJRGuitars1  is offline
Posts: 11  -  iTrader: (0)
Re: Truss rod screw loose and still not enough bow
For single action truss rods there should be some bow when the truss rod tension is released. Otherwise it's considered a bad neck (if it's new guitar, exchange it for another). A qualified tech can induce bow by applying heat to the fingerboard - which softens the glue joint between it and the maple back - at which point bow is created using clamps. The neck is then allowed to cool back into its new, bowed shape. It's an extreme solution, but it does work.
Old 01-26-2010, 08:18 AM
XcitR  is offline
Posts: 78  -  iTrader: (2)
BJR is right... been there, done that! It is fixable, but make sure to take it to a reputable guitar tech. The glue has to be heated and the neck bent slowly as the glue re-dries. The guitar tech used a neck heater and the right clamps and had to adjust it a little at a time until it was fixed (mine took over a week following.) Happy to report, there is now tension on the truss rod and everything is the way it should have been.
Old 01-26-2010, 01:03 PM
Manticore  is offline
Posts: 593  -  iTrader: (0)
sounds like a warrenty issue to me
Old 01-27-2010, 03:11 PM
CrossingStar  is offline
Posts: 1,051  -  iTrader: (2)
The quick thing to do is take the neck off and stand on it. Depending on your weight I suppose, maybe one foot. I have an old Ibanez Roadstar neck that, when I tighten the rod, then back it off it sticks in the tightened position. So I stand on it and it gives. Although, this is a beefier neck and I weigh 130lbs.
If you're too timid for standing, maybe take the neck off and give it a quick push with your arms while it's flat on the ground, using your upper body.
When I stand on it I have the head stock and heel raised up a little with blocks.
Old 01-30-2010, 01:26 PM
yikes, that all sounds quite extreme...
Well, A week after I installed the 4th trem spring I got a tad extra relief, so that helps ! Weather is very dry these days (we're not used to that) as well. My other guitars have a straighter neck as usual.
truss rod
Truss rod too loose? AirGuitar Tech: Setup, Repairs and Mods 11 04-08-2011 01:02 AM
OFR loose arm Rike81 Gear and Equipment 2 10-02-2008 03:53 AM
need help with S470 ZR Trem - loose screw Hairp1ck Other Ibanez Guitars (including Premiums) 1 07-20-2006 10:38 AM
Loose Truss Nut (REALLY need help here guys) genesis Tech: Setup, Repairs and Mods 6 06-27-2003 11:56 AM
I have a screw loose! - LO Pro Edge problem. jem7vwh JEM and Universe Guitars 2 03-13-2001 08:23 PM
