You may have seen my recent thread about my Schecter's truss rod. But I'll tell the story again:
I have a
Custom Shop Schecter that I bought in January. The lower frets were buzzing, and it got to the point where my first fret was literally making zero noise. So I went and got it professionally set up. It was great.
Now, about a month after the set up, my lower frets have started to buzz again. I believe this could be attributed to temperature change; the season changed pretty rapidly. But this doesn't make complete sense because I haven't taken my guitar outside, like, at all. If it's been outside, it's been in its SKB case. I doubt that problems would arise there.
So my lower frets are buzzing again. Today, I made a slight adjustment--I made an approximately 1/8 turn counter-clockwise. No, my truss rod didn't break or anything. But I made the problem worse.
I am severely confused. I understand that little to no neck relief=buzzing on lower frets, right? The headstock is coming towards the strings--a frontward bow? Yes. That is what I understand the case to be. The remedy, I'm told, is to adjust the truss rod counterclockwise, which I did, and hey! My strings are buzzing even worse, and the problem is afflicting frets as high as the 11th and 12th frets; before, it only went up to about the 8th.
Now, I'm really confused. When I look at the neck, I see a sort of backward bend, and now I'm thinking that either that's the way it's been or, I'm seeing things because the neck has a backwards neck arch like a Les Paul (it is a set-neck mahogany neck, by the way).
I would post pics, but my parents have my digi cam for their sailing adventure in Florida.
I am 100% sure that my truss rod isn't one of those "backwards" ones, where tightening it does the opposite of what you expect. I've heard of that. But my
guitar tech did a superb set up, and he didn't tell me anything like that, and he probably would have snapped the neck or something if it were backwards.
SO! I think I'll just blow $50 and have the guitar tech redo the setup.
Final question though...will the new setup "hold," or will I have to get it done again?
Smitty
