Old 05-17-2007, 10:29 AM
Ibanezer_hi  is offline
Posts: 109  -  iTrader: (0)
TRUSS RODS....a question
Apparently they're quite important in keeping the neck playable n'stuff but i cant understand what they do exactly if you have a locking trem...
I mean how can the truss rod affect the strings at all if they're locked in position ? ?
Old 05-17-2007, 10:32 AM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Re: TRUSS RODS....a question
The truss rod is there to stop the neck from warping like a banana! It's adjustable, so you can loosen it or tighten it depending on how the guitar is set up, what gauge strings are being used, etc. Nothing to do with the trem. It lives inside the neck.
Click here for a more in-depth explanation: http://en.wikipedia.org/wiki/Truss_rod
Old 05-17-2007, 10:36 AM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Some guitars necks are more sensitive than others when it comes to warping. If a guitar is kept in different temperatures, that can have an impact on the neck with regards to warping.
Jimmy
Old 05-17-2007, 05:46 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
read Rich's tech section - all of it.
Old 05-17-2007, 06:56 PM
Racerx2k  is offline
Posts: 1,076  -  iTrader: (0)
Truss rods are a sort of counterbalance to the string tensions, if you will. The strings want to pull the neck one way, while the trussrod counters those forces, pulling it in the opposite direction. Doesn't take alot on most guitars. Normally, a quarter turn or less suffices.
Old 05-18-2007, 08:21 AM
My Apologies ,i thought the truss rod was the little bar you find after the locking nut on the head stock like in this pic ...
http://www.diyguitarist.com/Images/MIJS-Head.JPG
Ive learnt something new already today then..
Old 05-18-2007, 08:43 AM
Eco  is offline
Posts: 693  -  iTrader: (0)
Thats a string retainer bar.
Old 05-18-2007, 08:46 AM
Dee  is offline
No apologies necessary, my friend. We all gotta start somewhere and it's cool that you're learning. Stick around and you'll learn lots more.
Old 05-18-2007, 09:21 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
so, your question would turn like that:
"how can the RETAINER BAR affect the strings at all if they're locked in position?"
it doesn't. it only assures that the strings sit right on the nut top from the fretboard side to the headstock side. if the retainer bar isn't set low enough, the strings would "raise" from the nut top, and when you lock down the pads, those would press the strings down, thus altering the tuning.
Old 05-18-2007, 09:28 AM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
Lol....nice diagram, nuno
Old 05-18-2007, 09:43 AM
Dee  is offline
Gotta love nuno's diagram's.
Old 05-18-2007, 10:38 AM
nuno  is offline
AutoCAD and a free Photoshop clone can make miracles
Old 05-18-2007, 12:19 PM
I dont understand what you mean but i'm sure your right.
Old 05-18-2007, 12:52 PM
nuno  is offline
is there some english mothertongue willing to explain it better? thanks
Old 05-18-2007, 01:09 PM
0americana  is offline
i think of the retaing bar as a counter to the slight pitch change when the hut is locked.
If the strings arent parallel with the nut , when it is lock the string change pitch.
gauge strings, locking nut, retainer bar, string tension, truss rod, truss rods
Question about truss rod adjustment fettouhi Tech: Setup, Repairs and Mods 3 12-20-2006 07:39 AM
another question about the truss rod.... jcm900 Tech: Setup, Repairs and Mods 2 02-24-2006 11:17 AM
jem truss rod question? kennyg Tech: Setup, Repairs and Mods 4 06-11-2003 10:59 PM
Simple truss rod question Jupiter Tech: Setup, Repairs and Mods 9 04-06-2003 09:48 PM
JEM truss rods - truss rods pskomra JEM and Universe Guitars 1 05-02-2001 12:02 PM
