Old 03-10-2005, 11:19 AM
dc_mally  is offline
Posts: 26  -  iTrader: (0)
tuner for intonation
hey, i need an accurate tuner for setting intonation. im not sure which are best but cheep. hows the boss tu-2 and tu-6 (i think)??
and whats the difference with a chromatic one and none??
Old 03-11-2005, 07:33 AM
GTR-MAN  is offline
Posts: 1,056  -  iTrader: (0)
Images: 8
Re: tuner for intonation
I got a BOSS TU80, and it works but I don't really think they are the best for intonation. Everything I've read says a strobe tuner is the most accurate and best for intonation. I recently bought a "Peterson Strobe" tuner and it makes a big difference. I'm still new to it but I've noticed right away how much more accurate it is than any other tuner I have. Though they aren't cheap, as I paid $219 for it. I think I paid around $50 for the BOSS. Maybe you can find a inexpensive strobe in ****. Good luck.
Old 03-11-2005, 06:00 PM
Dylan7620  is offline
Posts: 636  -  iTrader: (1)
with a floyd equipped guitar especialy your best best is a strobe... others can get "close" but it depends on if you really want to be in tune
Old 03-12-2005, 01:28 AM
buddroyce  is offline
I wish I owned a Peterson strobe tuner. Too rich for my blood though.
Korg makes a tuner designed for techs/luthiers to do the Buzz Feiten mod and is significantly cheaper than a Peterson strobe. I mean if it's good enough to Feitenize a guitar, it's accurate enough for me. (It's what I use in my shop to intonate guitars)
Old 03-14-2005, 09:36 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
What is the model of the Korg you mention?
Old 03-14-2005, 10:52 PM
yes, but most of the "feitenizing" comes from the off tuning which involves each string to be a cent or few off.... much of this effect can be done by simply tuning to ear after its been tuned. intonation is a little more difficult.
Old 03-15-2005, 12:33 AM
The Korg I use in my shop is the Korg DT7(at least I think that's the model #).
As for Feitenizing, it's actually a combination of changing string length(shifting the nut) and reintonating the bridge so it's actually a few cents off. There are only a handful of tuners capable of being accurate to the cent enough to feitenize a guitar. For an "accurate" tuner, aside from a Peterson tuner, the next best thing is the Korg DT7.
Note: feitenizing was only used as an example to indicate how accurate the tuner was.
Personally, I tune guitar that are not feitenized a little sharp on the highs and a little flat on the lows for a similar effect to feitenizing(something I learned from Eric Johnson before I discovered feitenizing).
buzz feiten, equipped guitar, eric johnson, strobe tuner
Best way to send a clean signal to tuner?? ChrisReedSmith Gear and Equipment 6 10-03-2004 12:26 PM
Which tuner? Drache713 Gear and Equipment 4 05-11-2003 08:26 PM
More accurate tuner - Korg GT-12? trajectory fish Gear and Equipment 43 05-08-2003 01:38 PM
Rack tuner - can I put a tuner in the effects loop? - I coul djrjems Gear and Equipment 5 02-13-2002 10:55 PM
need help with guitar tuner - the right pitch Neven Gear and Equipment 5 12-27-2001 02:16 PM
