Old 05-14-2009, 09:34 PM
toddw7  is offline
Posts: 79  -  iTrader: (1)
Tuner question
Hello.
I might be over-thinking this and I'm not sure if I'll be able to explain it clearly. I just got a Boss TU-12 tuner, and it's pretty sensitive to subtle changes in pitch. When you pluck the low E string, for example, the initial attack causes a spike in pitch, which quickly goes flat by about 20 cents. How long after I pluck the string should I waint? Should I tune using the initial attack? Or should I wait a second or two after plucking the string so the needle levels off?
Thanks,
Todd
Old 05-15-2009, 06:38 AM
Pursuit  is offline
Posts: 680  -  iTrader: (0)
Re: Tuner question
That is not limited to the TU-2, my better tuner does the same.
All I do to avoid this initial attack confusion is to not use a pick when tuning. If you hit it with your thumb, the pitch should be much easier to tell.
Old 05-15-2009, 08:07 AM
Vim Fuego  is offline
Posts: 908  -  iTrader: (2)
Images: 6
Re: Tuner question
How 'bout this for a thorough discussion....
http://www.endino.com/archive/tuningnightmares.html
As for *why* which he doesn't explain, on the initial impulse the string tension is raised by the pick attack, as the deflection of the string gets smaller (amplitude decays) the tension returns to its normal value.
Jim
Old 05-15-2009, 06:27 PM
toddw7  is offline
Re: Tuner question
Thanks guys. I will check out that article as well.
tuning
Ibanez reverse headstock tuner upgrade to locking tuners question. unconventional Tech: Setup, Repairs and Mods 9 04-04-2008 01:20 PM
RG 565 TUNER/TUNING PEGS QUESTION bdk Gear and Equipment 1 03-16-2008 07:15 PM
Tuner Spacing Question Tool Tech: Setup, Repairs and Mods 1 05-05-2005 06:17 PM
LSR Tuner Question The_Grindfiend Tech: Setup, Repairs and Mods 7 04-16-2003 08:20 PM
Rack tuner - can I put a tuner in the effects loop? - I coul djrjems Gear and Equipment 5 02-13-2002 10:55 PM
