Old 05-12-2003, 09:31 AM
Shredd  is offline
Posts: 24  -  iTrader: (0)
Tung oil hardening
Heys guys, i got a question...
How long does it take for tung oil to totally harden and be able withstand unwanted substances?
I am asking this because I had left my newly coated neck to sure for 40 necks, but Oops! I accidentally spilled some lemon oil on it. Not a lot though.
Do I have to re-tung-oil my neck, or can i just leave it??
Old 05-12-2003, 09:49 AM
bammbamm  is offline
Ummm.... WHAT?!
It normally takes 24-48 hours for tung oil to cure depending on your enviroment, but unless you can see a spot that is discernably blemished, I wouldn't think you'd need to refinish it.
Bamm
Old 05-12-2003, 12:23 PM
Akhenaten  is offline
Posts: 728  -  iTrader: (1)
Aren't you the guy that about a month ago asked how much to put on there, and when everyone said a coat would do it, you put on like 4 or 5 anyway? If you put it on that thick, it just turns into a gooey mess. It never gets shiny and thick like the laquer finishes. If you did it right it should have cured by now. It's usually only a 1-2 thing.
Old 05-12-2003, 12:34 PM
Shredd  is offline
Nope, that was not me. Think it is by Drew?
Old 05-12-2003, 04:53 PM
lol... oh well. Either way, you should be fine, so long as you wiped the thing down after your spill. Lemon juice is a bit acidic, so I'm not sure how tung will react to it. But I assume you'd have not let it sit there to find out.
Old 05-12-2003, 04:54 PM
Doh...you said lemon oil, not juice...sorry...
Old 05-13-2003, 11:32 AM
Shredd  is offline
Its ok man. Thanks for replying anyway
Layer of tung oil seems ok...
Old 05-19-2003, 02:55 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Pretty sure it wasn't me... especially since I only put two coats on.
-D
tung oil
