Tech: Setup, Repairs and Mods
Tuning issue
01-27-2008, 12:20 AM
psp777
Posts: 86 - iTrader: (
Tuning issue
Whats the problem? I have a rg 550 20th anny issue. I tune my guitar via a tuner only to release the guitar is 1/2 step down tuned...I tune up again and its 1/2 step down tuned again..what is going on here? Thanks for your help...ITs like the tuning is slipping or something????
psp777
Find all posts by psp777
01-27-2008, 12:25 AM
jemplayer55
Posts: 2,627 - iTrader: (
Re: Tuning issue
Did you just re-string the guitar?
jemplayer55
Find all posts by jemplayer55
01-27-2008, 12:26 AM
CosmicDebris
Posts: 3,216 - iTrader: (
Re: Tuning issue
What do you mean by releasing and is this your first floating
trem guitar
CosmicDebris
Find all posts by CosmicDebris
01-27-2008, 12:28 AM
jemplayer55
Re: Tuning issue
Go read this..... Rich has a pretty good tech section which will help you understand what may be happening as well as resolving the issue!
http://www.ibanezrules.com/tech/setup/tuning.htm
jemplayer55
01-27-2008, 12:47 AM
psp777
Re: Tuning issue
No I own other floating trem guitars... no issues. I will read the article thanks.....
I just tune up then 5 seconds later its out of tune...about 1/2 step down.
Yes new strings
psp777
01-27-2008, 12:52 AM
jemplayer55
Re: Tuning issue
Did you stretch the string well? That may be the issue here as they may still be stretching out. That will surely have you re-tuning for awhile! Hope you get it resolved!
jemplayer55
01-27-2008, 01:24 AM
psp777
Re: Tuning issue
Thanks m8...i will research...the guitar is new and placed some new strings on it checked intonation etc....but this problem persits...worst case I will spend $50 at the
local guitar shop
for a pro set up but i am hoping to do it myself..thanks for the quick response..much appreciated m8
psp777
01-27-2008, 01:32 AM
jemplayer55
Re: Tuning issue
PSP your more than welcome..... can't stress enough about reading the entire tech area of Ibanez Rules. Rich is the Ibanez setup "guru" around these parts.
BTW, Did you change string gauge also?
jemplayer55
01-30-2008, 09:27 PM
psp777
Re: Tuning issue
I took my guitar into a tech today. he set it up with some hibrid strings...9-46 never tried those before.
I have a question for you guys...the tech had gone home for the day. The action seems to high for my liking. This is a fine line because i am used to playing a guitar with low action but being able to rest my hand on the bridge. When the bridge was much lower i found i had to alternate my playing style...just felt weird as i couldnt rest my hand so to speak on the bridge.
Now if I lower the bridge slightly to try to lower the action will this send everything else out of wack that i just paid for...ie) intonation etc...
I need to find that balance between a higher bridge and lower action
Thanks
psp777
01-30-2008, 09:48 PM
JeffWiredBeck24
Posts: 181 - iTrader: (
Re: Tuning issue
Lowering action won't affect your intonation or setup, but if it's a fairly major action adjustment you'll most likely need to retune.
JeffWiredBeck24
Find all posts by JeffWiredBeck24
01-31-2008, 03:01 AM
psp777
Re: Tuning issue
Thanks...so if I understand correctly its just a matter of tightening the two screws a bit...a little at a time ensuring i am tuned to pitch...seems simple enough. I thought it would impact the intonation or trem angle?
I just dont want to screw up a relatively great set up from the tech..just the action needs a small tweak.
This all may seem trivial to you but this is my 1st Ibanez in my 25 years playing and I want it to be perfect.
I always had my guitars set by a tech in vancouver BC canada but have now moved about 4 hours away...
Cheers
psp777
01-31-2008, 07:08 PM
JeffWiredBeck24
Re: Tuning issue
If you lower your action you'll notice the trem angle gets slightly lowered, but that's only because lower action means your bridge is sitting lower. Don't worry, it won't affect your set-up, especially if it's a minor action tweak like you said.
You should be plugged in to a clean channel while you're doing this though to check for buzz.
JeffWiredBeck24
01-31-2008, 08:26 PM
psp777
Re: Tuning issue
Ya I lowered the action but my intonation on the d string seems out of wack now..Im taking it back in to the tech tomorrow...I wasnt really happy with his work...goes to show you if you want it done right you have to do it yourself...Im learning...slowly
psp777
guitar shop
local guitar shop
trem guitar
how to do drop f tuning
when did tom anderson introduce buzz feiten tuning system
string gauge for b tuning?
mushroomhead tuning?
what tuning is this beadgb
Please advise on EdgeProII (555) wierd tuning issue
jemoctave
01:29 AM
Help with tuning nightmare!! RG2820
bhuether
05:08 PM
"acceptable" tuning stability
jeffrg270
10:12 PM
Tuning to baritone?
keithb
Gear and Equipment
07:02 PM
Creaking neck and Tuning instability
LimHae
12:50 PM
08:18 PM
