Tech: Setup, Repairs and Mods
Tuning niggles
08-17-2006, 05:43 PM
markg5150
Posts: 2,361 - iTrader: (
Tuning niggles
Hi everybody
I have a
Suhr Standard
with a "strat" style bridge. I have a problem when using the trem bar to a bit of a dive, the return to pitch is slightly sharp and is most noticable on the low E and A strings.
Neck bow, action and intonation are all fine, and the bridge is set flush to the body. Machineheads are Sperzels
What should I do? Should I screw the
trem springs
in slightly to increase spring tension?
I know you guys are mainly Floyd/Edge/etc experts but any help is much appreciated.
Mark
markg5150
Find all posts by markg5150
08-17-2006, 09:17 PM
Gex
Posts: 962 - iTrader: (
Re: Tuning niggles
98% of the time, when I encounter some tuning issue with a
strat style
bridge, its the nut's fault.
On the strings that go sharp, bend behind the nut a little, and see if they remain sharp. If they go back, it means that the strings are being pinched a bit by the slots being a bit to narrow for your current guage.
Or. .the string tees. . .those can be bothersome, especially the vintage style ones. But. . your problem is on the
low strings
. . .no string tees.. . so its likely the nut.
Gex
Find all posts by Gex
08-17-2006, 09:27 PM
David McCarroll
Posts: 2,049 - iTrader: (
Re: Tuning niggles
Yep - totally agree with Gex - no string trees, something like a GraphTek nut and
locking tuners
- minimum winds around the machine head post on the lowest strings could also help - the less angle over the nut, the lower the chance of the string binding in the nut slot - don't expect a
vintage trem
to behave like a Floyd though - with patience you can get them pretty good, but not really strings flopping loosely across the fingerboard good! Funnily on vintage style trems, it's normally the G which returns sharp when the trem is set up floating.
Cheers,
David
David McCarroll
Find all posts by David McCarroll
08-17-2006, 10:08 PM
jaxadam
Classified Watchdog
Posts: 3,042 - iTrader: (
Re: Tuning niggles
Huh, that's strange to me, because on my guitars that have a trem without a
locking nut
, whammy bar use usually results in my strings going flat, due to them binding at the nut. And it's usually my low E.
jaxadam
Find all posts by jaxadam
08-18-2006, 04:28 AM
markg5150
Re: Tuning niggles
Thanks guys I'll have a look at the nut, I hadn't thought of that
markg5150
locking nut
locking tuners
low strings
neck bow
strat style
string tree
string trees
suhr standard
trem springs
vintage style trem
vintage trem
how to do drop f tuning
when did tom anderson introduce buzz feiten tuning system
string gauge for b tuning?
mushroomhead tuning?
what tuning is this beadgb
korean locking nuts - loosin tuning does the hardware finish matters on tuning??
jlander
09:43 PM
Help with tuning nightmare!! RG2820
bhuether
05:08 PM
Tuning probs
Zeroleet
07:26 PM
"acceptable" tuning stability
jeffrg270
10:12 PM
Tuning to baritone?
keithb
Gear and Equipment
07:02 PM
09:50 PM
