Old 09-05-2002, 02:26 AM
GonWild  is offline
Posts: 93  -  iTrader: (0)
tuning problem on new 7dbk
I have a slight problem keeping my 7dbk in tune. The strings(9.5-44) have just been changed, but I've stretched them for a couple of days without locking the nut screws, so I don't thikn thats my problem.
And there is this odd thing...when the guitar is in tune, and I depress the whammy, the strings get out of tune. However, if I then pull the whammy away from me, the strings are in tune again. Almost as if the tremolo can't pull the strings back to the correct pitch.
Anyone know what I can do with this?
Old 09-05-2002, 07:11 AM
nuno  is offline
Posts: 4,525  -  iTrader: (0)
check the underside of each nut pad, check for burrs or something, then check the trem springs and, if needed, replace them with a new set.
be sure you lock the pads in the right way, you should see kind of ^^^ in a body-toward-headstock sight, and tighten them firmly.
also be sure the retainer-bar sits the lowest as possible and, if needed, take the truss-rod cover away.
hope this will help you, let us know.
Old 09-05-2002, 09:26 AM
horstausmforst  is offline
Posts: 663  -  iTrader: (1)
Hmm.. seems to me that the knife edges of your trem are the problem. Take the trem out and see if theres significant wear on them.. is your guitar really 'new' or did you buy it 2nd hand?? cause factory-new guitars shouldn't have that problem..
Old 09-05-2002, 10:29 AM
Rich  is offline
Posts: 16,871  -  iTrader: (20)
Probably knife edges, but until you run through the whole checklist... Evidently you'd didn't go where you were sent in the other thread you started
http://www.ibanezrules.com/tech.htm#Stability
http://www.ibanezrules.com/tech.htm#Flat_Knife
http://www.ibanezrules.com/tech.htm#Sharpening
Old 09-08-2002, 11:08 AM
GonWild  is offline
okey..took my jem back to the repairs. he wasnt really sure, cos is was an odd problem. Anyhow, he placed one of the springs in an 'half' arrow position. It made the guitar stay in tune better. It could also be a wear and tear problem, that I had to use the guitar a little. Anyway..it works fine for me now
Old 09-08-2002, 11:24 AM
BeastofLove  is offline
Posts: 795  -  iTrader: (0)
So he increased the tension applied by the springs?- Just having a hard time visualizing.
Hope it works out for you, but it still sounds like you had / have bad trem posts / knife edges, and the increased spring tension is only compensating for this problem.
-Ben
Old 09-09-2002, 04:20 AM
sniperfrommars1  is offline
Posts: 3,289  -  iTrader: (0)
yeah. Definitely sounds bad. You dont want to leave it in an arrow position as it limits your flutter a good bit.
Old 09-12-2002, 03:16 AM
GonWild  is offline
limits my flutter? ...eh. whats that?
Featured Products
Reviewed by 4 members
Add your review!
Reviewed by 6 members
Add your review!
Add your review!
Reviewed by 24 members
Add your review!
Reviewed by 3 members
Add your review!
Add your review!
Reviewed by 8 members
Add your review!
Reviewed by 5 members
Add your review!
Add your review!
Add your review!
Add your review!
Add your review!
Add your review!
Add your review!
trem springs
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
close
Sign up for free and join one of the largest communities of guitar lovers!
Our members will be glad to help you with anything you need!
Join over 30,000 JemSite members!
Email
Email Confirm Email
Username
Password Confirm Password
Where do you live?
I agree to the website rules
