Tech: Setup, Repairs and Mods
Twisted neck on my RG550 - any hope of repair?
Page 1 of 3
12-09-2007, 08:37 AM
bikeman
Posts: 660 - iTrader: (
Well I was planning on taking one of my old RGs to band rehearsal this week to give it an airing. I've not really played it since I bought it a while back, and I tried to set it up tonight. After slackening off the
truss rod
to get some relief in the neck (there was none) I found this problem
It's like someone's grabbed the headstock and the body to give the neck a twist like a chinese burn
Can this be repaired? Or do I now have a very 80s looking ornament???
bikeman
Find all posts by bikeman
12-09-2007, 08:45 AM
Davey
Posts: 4,783 - iTrader: (
Re: Twisted neck on my RG550 - any hope of repair?
Ouch, that's not the one I sold you is it? I certainly wasn't like that when I sold it you because like you know from the Eggle we dealt with, I always make sure to sight the neck as soon as I get to changing the strings.
Davey
Find all posts by Davey
12-09-2007, 08:48 AM
bikeman
Actually Dave, it IS the one you sold me! It's odd becuase I haven't used the guitar much and it's stored in a spare bedroom in the wardrobe. No extreme temperatures etc unlike a loft or garage. Bizarre huh?
I guess it's replacement neck time? Unless there's any way to straighten it????
bikeman
12-09-2007, 08:53 AM
Davey
Wow... not sure what's happened there then. Does it stay like that after tightening the truss?
I'd just take it to a luthier, have the fretboard plained (which will make it look practically new again) and have a re-fret done. Shouldn't cost much at all.
Edit: Just looked back, it was a year and a half ago that I sold you that guitar. Time flies!
09:00 AM
Davey
12-09-2007, 09:25 AM
bikeman
I know - crazy isn't it?
I can tighten the truss, but then I get no relief and it buzzes.
It's quite badly twisted, quite noticeable from the side. I think it's a case of trying to straighten it (some sort of clamp/split arrangement?) or a new neck. The planing/re-fret option won't fix the twisted back of the neck.
I guess this ones the player then and my other is the collectible
bikeman
12-09-2007, 10:42 AM
Algiman
Posts: 2,553 - iTrader: (
A steam press is probably the only thing that would be able to sort that, but given how easy RG necks are to buy you may as well save money and just replace the neck.
Algiman
Find all posts by Algiman
12-09-2007, 01:21 PM
albee1952
Posts: 784 - iTrader: (
Just curious if you string it with SKinny Top/ Heavy Bottom strings? I agree, just grab a new neck off the bay. I know several JEM rootbeer models that did the twist but they were all
rosewood boards
albee1952
Find all posts by albee1952
12-09-2007, 01:28 PM
bikeman
It's strung with regular 10s -
Ernie Ball
Slinkys.
New neck it is then
bikeman
12-09-2007, 02:00 PM
jim777
Posts: 8,943 - iTrader: (
Something like that happened to mine, though not as severely. I had it refretted, and then had the frets ground and polished to that the frets were right despite the neck. If you can straighten that a bit you could likely do the same, but a new neck might be the same price. That's a good twist you got there, unfortunately.
jim777
Find all posts by jim777
12-09-2007, 02:22 PM
bikeman
Yeah, it's fairly major.
Replacement necks look like hen's teeth for the old block heel joint though - and the new RG20ths aren't a direct swap over either.
Might have to look at a custom order...
bikeman
12-09-2007, 03:07 PM
brothersnowgone
Posts: 1,498 - iTrader: (
Reviews: 7
bikeman
He said it was an old RG, so it's not that hard to find a replacement neck for it.
brothersnowgone
12-10-2007, 09:00 AM
bikeman
Thanks for all the advice folks.
I've just spoken to my
local luthier
on the phone and he's suggested a "heat and clamp" treatment, which he has done before. I've used him for other (more minor) work in the past and he's done an excellent job so I feel I can trust him with this. He says a full setup and neck treatment is going to cost me about £90 so I'm going to give that a go. I really hope he can save the original neck as it's so superb to play.
Fingers crossed....
bikeman
12-10-2007, 12:29 PM
jazzedout
Posts: 671 - iTrader: (
Good luck! I certainly hope you can fix it!
jazzedout
Find all posts by jazzedout
12-10-2007, 12:39 PM
Batchimp RG
Posts: 2,378 - iTrader: (
Good luck, man. Let us know. £90 to have it repaired (as new, hopefully) is not that bad....and, hopefully, it will be done quickly.
Batchimp RG
Find all posts by Batchimp RG
12-10-2007, 01:27 PM
Ayrton
Posts: 4,157 - iTrader: (
44
You may be able to send it back to Ibanez, and but a replacement neck direct.
Ayrton
Find all posts by Ayrton
Page 1 of 3
ernie ball
fret level
fret wire
local luthier
neck joint
rosewood board
rosewood boards
truss rod
truss rod nut
ibanez rg550 road flare red color code
parker are they neck thru
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
Jem neck vs RG550 neck
Devon8822
05:41 PM
what is this neck called? rg550
kooshball
04:35 AM
WTB: Neck for 92 RG550 - Non AANJ
JimmyJ
11:08 PM
Very loose neck to neck pocket fit, what do I do?
SilverSurfer2
10:00 PM
01:03 PM
