unwound g-string vs. wound g-string - Jemsite
post #1 of 4 (permalink) Old 02-26-2004, 12:10 AM Thread Starter
the string gauge i'm going to be getting soon contains both an unwound and a wound g-string it, and i'm not sure which i would want to use. it's 11-60 7-string set (with an 18 plain g-string and a 20 wound g-string) that i'm putting on my 7421xl. I know with a wound string it'll be slightly harder to play, but i've heard various arguements for it including better tone and intonation, and i know bigger strings in general sustain better and sound fuller/bigger. now adjusting the intonation/action/truss rod to accomodate the wound g-string wouldn't be much of a problem, but would I have to mess with anything else like pickup height or pole pieces or anything? can you guys steer me one way or the other?
Drache713 is offline
post #2 of 4 (permalink) Old 02-26-2004, 12:55 AM
Bigger G-strings are kinda uncomfy, but when you get use to the perpetual wedgie that you have I'd expect you get use to it
But in all seriousness, you shouldn't have to worry about the pickup height at all. If you're happy with the tone you've got atm, just leave the pickup height the same. If the sound changes to the point that you don't like the way it sounds (too muddy), drop the pickups lower.
You shouldn't have to adjust the truss rod, atleast I wouldn't think it would make *that* much of a difference.
wil..
wilch is offline
post #3 of 4 (permalink) Old 02-26-2004, 02:18 PM Thread Starter
yea, i've also read that as an un-wound 3rd string gets older, it's harmonics start to become out of tune with the fundamental that's not good, so i might give the wound third string a try.
post #4 of 4 (permalink) Old 02-26-2004, 04:41 PM
The original Fender single coil stagger was for a wound G. So the balance from string to string is more appropriate with a wound G. But almost every modern guitar hero uses/used a plain G, so don't take that to mean "better."
The split between wound and unwound strings is dramatic. Not just in feel, but in tone, volume, and intonation. If you look on a standard bridge there's sort of a separation to the intonation. From the high E down it goes: "close/mid/far/close/mid/far." If you look at a compensated acoustic saddle it's: "close/far/close/mid/mid/far." The wound G no longer is the most "intonation sensitive," and therefore farthest back of the top three, rather it is less sensitive, and closer forward like where the D is. So your intonation will need to be adjusted, much more than just changing gauges of plain strings.
Bends on the wound G will be less responsive. You'll have to bend farther to reach the same pitch as a plain G. Finally back to the pickup stagger, you may find yourself raising adjustable poles under the G like Fender singles, to make it more audible against the other strings. A long time ago I thought I'd like a wound G and I didn't.
frankfalbo is offline
pickup height , truss rod , wound strings
Human Verification
Ibanez Iron Label RG 6 String vs. Jackson DK2M Pro Series Dinky 6 String ? Riley Macdonald Other 6-string Guitars (non-Ibanez brand) 6 06-16-2013 12:35 AM
Did you guys see the Ibanez 9 string prototype from namm? (8 string j custom inside) WYLD STALLYNS Other 7+ string Guitars 12 02-02-2013 11:31 AM
WTB: Left hand tuners, top-mount nutlock and string retainer for Ibanez 7 string (UK) leec Classified Ads: Guitars and Gear 4 09-05-2012 09:33 AM
Bass pickups in 7 string and 7 string single coil demo juiceofvenus Pickups & wiring 4 08-29-2003 02:54 PM
7-String Tune-O-Matic? 7-String String Saver Saddles? Drache713 Other 7+ string Guitars 1 12-03-2002 11:27 PM
