Old 05-31-2006, 07:41 PM
jem_fanatic  is offline
Posts: 212  -  iTrader: (0)
Exclamation
URGENT trem and pickup questions
so im swapping a lo-pro trs trem for a lo-pro-edge on an Rg450 im working on and was wodnering when replacing the studs do i take jus the part that touched the trem out or all of the stud includint what it screws into out and put in the new stud pieces??
also im installing 2 new humbuckers they are bill lawrence L-500's and need a wiring diagram for a h-s-h 5 way switch config
1-bridge
2-single bridge and midlle single
3-middle single coil
4-neck single and mid single
5-neck
HELP!!!!!!
Old 05-31-2006, 07:49 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Re: URGENT trem and pickup questions
As far as I know, you cannot replace a TRS with an Edge, it doesn't fit -- you gotta hack the body up.
Old 05-31-2006, 08:08 PM
dude all the routing has already been done, and its a lo-pro edge just to clarify
Old 05-31-2006, 08:13 PM
SonataGuitarist  is offline
Posts: 408  -  iTrader: (2)
Heres your diagram, which is all over the Dimarzio website.
http://www.dimarzio.com/media/diagrams/C.pdf
2 seconds of research will get you all you need, urgent or otherwise.
Old 05-31-2006, 08:20 PM
i hope these bill lawrence pickups have trhe same color scheme........
Old 05-31-2006, 08:28 PM
Dee  is offline
OK.
Old 05-31-2006, 09:28 PM
Most likely there not. But it's usually pretty easy to figure it out. Never used/seen a BL pup, but if it's 4 conductor then no prob.
On Dimarzio, green and bare are always grounded, and black and white always go together, and red is hot as well. No doubt your BL came with descriptions of which wire is what, so from there it's just working it out.
I actually just wired a Breed bridge to my SG about an hour ago. Good luck to ya.
Old 05-31-2006, 09:48 PM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
That's true unless you have (2) pickups are out of phase. If this happens, then you have to reverse the red and green wires so green will go to hot and red and bare go to ground. Just something to be aware of.
Old 05-31-2006, 09:59 PM
Dee  is offline
I can tell you from wiring up a Bill Lawrence that it differed slightly from my Dimarzio. Basically:
Dimarzio green = Bill Lawrence black
And of course Dimarzio Black = Bill Lawrence green.
The rest are the same.
Old 06-01-2006, 02:27 PM
Rob A  is offline
Posts: 69  -  iTrader: (0)
If ya have a look on Project Guitar, there is a tutorial - you need to check is the stud holders are the same size as the existing ones, and if they're in the right place. Have a look here: http://www.projectguitar.com/tut/trs2lopro.htm
Old 06-01-2006, 06:00 PM
thanks guys ill let you know how i fair out
Old 06-01-2006, 09:39 PM
Ironjose  is offline
Posts: 1,060  -  iTrader: (0)
Nice link... i guess you already done this? but i have a question thou, i have a GIO RG which has the Trs tremolo... and of course you´ve guess it i want to change it for an OFR but i know the original fits but i dont know if the OFR pro will? and i want the PRO.
JJ
Old 06-03-2006, 03:03 PM
hey guys ive run into a small problem with the locking nut , it hasnt ben tapped for the bolts that secure it at the back of the neck, what tap do i use to tap it????
breed bridge, locking nut, pro edge, wiring diagram
Ibanez S 7420 TRS to Edge trem and pickup recommendations tritheory Other 7-string Guitars 5 10-20-2005 02:53 PM
String height? Blocked trem.. DotNetTim Tech: Setup, Repairs and Mods 2 06-14-2005 09:44 AM
new bridge pickup for an RG1570 momitch Pickups & wiring 2 06-27-2004 03:11 PM
Filling trem cavity - Just thought I'd run this by you guys. ChrisReedSmith Tech: Setup, Repairs and Mods 6 07-19-2001 03:29 PM
Blocking the trem on my RG7620? - Because going out of tune RedFive Tech: Setup, Repairs and Mods 1 04-22-2001 06:35 PM
