UV Mods - Need some questions asnwered.
Hi Guys
Well what I plan on doing will probably be considered sacriligious to most UV fans...but here it goes anyways.
1- I would like to replace the mirrored pick guard with a plain black one, same width, same size.
2- Since I never use the center pick-up, I would like to remove it.
So here is my dilemma: where can I find a nice black pick-guard, that it will fit perfectly on my UV. Is it possible to find one that doesn't have a center single coil hole?
If so and I remove the single-coil, what happens then to my 5-way selector switch. Will I have to swap it for a 3 way? Or can I keep the 5-way without any problems?
Thanx
