Tech: Setup, Repairs and Mods
UV neck - Rough
01-07-2002, 12:31 AM
Scoff X
Posts: 211 - iTrader: (
UV neck - Rough
I played a new UV777bk this past week...the neck felt like silk..
MINE DOESN'T!!!!!!!
it feels course...how do I fix it...
I'm sure i just need to sand it....anyone have a tutorial on it?
I think I saw one from rich
Scoff X
Find all posts by Scoff X
01-07-2002, 12:41 AM
Posts: 19,344 - iTrader: (
UV neck
Unless you want to sand it, I'd just use 0000
steel wool
to smooth it out. If you don't want to remove finish use burlap or something similar.
01-07-2002, 12:43 AM
UVmanMike
Posts: 128 - iTrader: (
UV neck
Just go get some 0000 steel wool, mask off the body around the
neck joint
, and sand away. Go with the grain, not against it and the neck will be super-smooth....
Mike
UVmanMike
Find all posts by UVmanMike
01-07-2002, 01:12 AM
Scoff X
UV neck
It has a finish???
the back of my UV777bk didn't seem to have a finish...am I wrong?
Scoff X
01-07-2002, 10:43 AM
ripl3y
Posts: 747 - iTrader: (
UV neck
Sounds to me like someone sanded down the back of your neck to make it smooth but did a half arse job of it (unless you bought your UV new that is)
http://www.jemsite.com/tech/t_2mods.htm#necksand
Steve
ripl3y
Find all posts by ripl3y
01-07-2002, 03:19 PM
Scoff X
UV neck
Bought it brand new...never played before
Scoff X
01-08-2002, 08:48 PM
trouble311
Posts: 643 - iTrader: (
UV neck
Aren't UV777BKs and JEM10ths the only recent models to have unfinished necks? *Glen? *Rich? *Kevan?
trouble311
Find all posts by trouble311
01-08-2002, 11:12 PM
jemsite
Administrator
Posts: 9,270 - iTrader: (
UV neck
trouble311 on 7:48 pm on Jan. 8, 2002
Yup, they're lightly oiled without the annoying poly-acrylic... glen
jemsite
Find all posts by jemsite
neck joint
steel wool
parker are they neck thru
how can i tell thin or standard neck prs
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
05:41 PM
