If the body is stripped and you're just talking about 1/16th" or less, you shouldn't have to plane it. If you removed the finish already, that's about 1/16th-1/8th" depending on the guitar. Then your new finish, if it's an oil finish or a gloss from a spray can won't be as thick as a factory poly finish anyway. If you are going with a bent 1/4" or even 1/8" top, then you have to plane and bend. Otherwise the paper thin veneer will bend while you're appling it. You don't have to wet it.
