Old 12-05-2006, 09:49 AM
Dazza1004  is offline
Posts: 265  -  iTrader: (4)
Visual differences btw edge pro & edge pro II
Can someone please tell me how to spot the differences between an edge pro and edge pro II
I have done a search but couldn't find the answer
Thanks
Old 12-05-2006, 10:15 AM
damo7v  is offline
Posts: 1,150  -  iTrader: (10)
Re: Visual differences btw edge pro & edge pro II
perhaps the biggest giveaway is the lack of steel insert ("Sound Metal Chip") at the intonation point on the edge pro II. edge pro II is also shorter, though that might be harder to spot with the naked eye.
Old 12-05-2006, 10:18 AM
sugizo_esp  is offline
Posts: 446  -  iTrader: (0)
edge pro has some metal chip on each saddle that holds the string, EPII doesnt have it
EP has a gloss color hardware
EPII is dull color
Old 12-05-2006, 10:32 AM
damo7v  is offline
EPII is dull color
not necessarily
Old 12-05-2006, 11:39 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
Edge-Pro
Edge-Pro II
judge yourself...
Old 12-05-2006, 02:59 PM
projectjem  is offline
Posts: 664  -  iTrader: (0)
visually its those bars/string guides.
Old 12-05-2006, 03:08 PM
timi_h  is offline
Posts: 1,104  -  iTrader: (0)
also the fine tuners are thinner, more like on an OFR
Old 12-06-2006, 09:13 AM
Thanks for the info guys
Old 12-10-2006, 10:55 AM
Ironjose  is offline
Posts: 1,060  -  iTrader: (0)
the edge pro has a bigger block and is quite larger than the edge pro II...
JJ
Old 12-12-2006, 06:29 PM
Martallica  is offline
Posts: 342  -  iTrader: (1)
Where the wammy bar go's into the trem body I think is the easiest way to spot the difference the edge 2 has just a hole and the edge is like old conventional way.
Edge III swap for another Edge model trem? lespaulreedsmith Other Ibanez Guitars (including Premiums) 36 03-14-2009 06:10 PM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
Edge Bridge Differences cworley5150 JEM and Universe Guitars 7 02-15-2006 06:14 PM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 12:29 PM
Visual differences between Breed and Evolution pickups... pseudomarine Pickups & wiring 16 02-20-2003 06:31 AM
