Tech: Setup, Repairs and Mods
Volume Pot and Selector Mod - suggestions
Page 2 of 2
08-29-2001, 03:59 AM
rickboot
Posts: 332 - iTrader: (
TH,
I think what you are trying to do is feasible. This scheme will certainly will be very flexible.
You may be able to achieve the same configurations in a more intuitive way. How about adding a push-pull to split the bridge and a push-pull or toggle to turn on the neck or
bridge pickup
. By doing this you can have the 5 way control the pickups in a the traditional manner, but still get the bridge and
neck pickups
on at the same time.
By the way, Stewmac is great to deal with. I buy a lot of my tools and parts from them.
Rick
rickboot
Find all posts by rickboot
08-29-2001, 04:07 AM
rickboot
Oh and about the turning down the volume to clean up your sound...
Are you trying to clean up a high-gain setting? If so what you are experiencing is normal.
Whether using the volume control to clean up your sound works well depends a lot on your rig and your pickups. The
Super Distortion
is a very hot pickup. So you REALLY have to turn down a lot to clean it up. The other issue is the amp and its settings. If you are running an with a high-gain preamp setting then cleaning up the sound by turning down the volume may not be possible, because almost any signal you run into the amp will sound distorted. This problem will be compounded by a hot pickup. Try backing off on the
preamp gain
a bit. That may help.
Rick
rickboot
08-29-2001, 09:04 AM
sixstringphoenix
Posts: 345 - iTrader: (
Rick,
The distortion I'm using is a DS-1, like I said above, and I'm running it in the clean channel of my amp. I noticed that the pickups in my RG (Evo/YJM/Breed) don't clean up nearly as well (knobs aren't good either). On the other hand, my [MusicMan] Axis does, but I left the stock pickups in. Any suggestions for [DiMarzio] pickups that will sound good and clean up as well?
-Justin
sixstringphoenix
Visit sixstringphoenix's homepage!
Find all posts by sixstringphoenix
08-29-2001, 04:32 PM
Two hands31
Posts: 4,989 - iTrader: (
Thanx for the help. *Does anyone have any idea of how to wire the megaswitch for what I want? *I'm running on a limited budget, so I want to do this with as few new parts as possible. *rickboot: *Would putting a higher capacity volume knob help? *I am using very high gain stuff.
Two hands31
Visit Two hands31's homepage!
Find all posts by Two hands31
08-29-2001, 05:13 PM
Devo
Posts: 1,483 - iTrader: (
the higher the value of the pot only means you get more treble through, as lower value pots bleed treble (hence fenders use 250's to add warmth to the sound)
a
wiring diagram
of sorts comes with the megaswitch with several different wiring options .
Devo
Find all posts by Devo
08-29-2001, 08:45 PM
rickboot
The Breeds and Evos are hot too, but I wouldn't change them. I'd start playing with the gain (dist knob) and especially the output level (level knob) of the DS-1. If that fails, try taking the DS-1 out of the loop and find an amp setting that will work.
As you mentioned people use the volume to go from an overdriven to a cleaner sound. Going from really distorted to clean with the volume pot is probably a bit much to expect. If you want to do that I think some foot stomping is going to be necessary.
Being more of a foot switching sort of guy I'd like to hear from somethat is a volume pot rider. Anyone?
Rick
rickboot
08-31-2001, 09:12 PM
Anonymous
Posts: 347 - iTrader: (
Try finding an MP3/video of Bon Jovi on "Storytellers". *Preferably the ending of "Wanted Dead or Alive" or the middle section of "Just Older". *That's where I first saw this done.
Anonymous
Find all posts by Anonymous
09-01-2001, 06:13 AM
rickboot
Please don't force me to watch a Bon Jovi video!
I seriously doubt changing the pot will help. Focus on the gain of your pickups, pedal and amp.
Let me know if you need help with the wiring.
Rick
rickboot
09-02-2001, 10:58 PM
Two hands31
lol *Ok. *He just gets some great Strat sounds on that show.
Two hands31
Page 2 of 2
boss metal zone
bridge pickup
dimarzio super distortion
foot switch
neck pickup
neck pickups
pickup combination
preamp gain
squire strat
strat sound
super distortion
wiring diagram
volume pot is stuck
what is pu selector switch
how to wire an on-on selector switch
emg 81 what volume pots
noise when volume knob
04:13 AM
