Old 05-03-2007, 09:22 PM
guitarman13  is offline
Posts: 388  -  iTrader: (0)
Volume Pot on my RG Just Completely Seized Up
I few minutes ago I was turning the volume knob on my guitar down and, all of a sudden, it got stuck and wouldn't turn. Then, the whole volume pot came completely loose and I have no idea what the hell happened. It's only a few months old. Anyone got any ideas?
Old 05-03-2007, 09:33 PM
Re: Volume Pot on my RG Just Came Completely Loose
I just took the knob off, tightened the volume pot, and put the knob back on. Now the knob turns but it sort of grinds and is extremely stiff. I don't understand how a volume pot can just seize up like that.
Old 05-03-2007, 09:36 PM
Petie  is offline
Posts: 2,878  -  iTrader: (0)
O_O Another one? This has also happened to me and Dee with our new Ibanezes.
What model guitar? What year was it made?
Old 05-03-2007, 09:37 PM
It's an RG1570MRB made in 2006.
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Exactly what happened to mine, a brand new one my RG 20th. One minute it was fine, the next, completely unable to be moved! Not so good when you're in the middle of a recording session.
Just get it replaced man, or at least try spraying some switch cleaner / lube in there. It should sort it out. It sorted mine out a little, but still needed replacing because it felt crap and I had to use a lot of force to turn it. Keep in mind: Dimarzio pots have a larger shaft than Ibanez ones, so avoid those if you need to replace it. Unless of course you want to make a larger hole in your guitar.
Old 05-03-2007, 09:49 PM
Petie  is offline
It happened to my Jem 7VWH (07 serial number but 2006 date on the inspection card). Is your guitar under warranty? Mine was, and I was sent a replacement pot, but it's the same kind so I'm a little concerned it may happen again.
Old 05-03-2007, 09:51 PM
Dee  is offline
Did you put any spray lube in there Petie? In the UK we have some stuff called WD-40. I don't know if you have that in Oz, but there must be something similar.
http://www.wd40.com/
Old 05-03-2007, 09:59 PM
Rich  is offline
Posts: 19,355  -  iTrader: (21)
Somebody else just wrote me of their new 1570 pot freezing up. I'm starting to suspect a bad batch of pots.
edit, you're the one that wrote
Old 05-03-2007, 10:00 PM
Dee  is offline
YES!!! I am not alone!
Old 05-03-2007, 10:07 PM
Is there a different brand of pot that I could replace it with that's better than the Ibanez ones?
Dee  is offline
I'm not sure. Rich should probably know the answer.
Old 05-03-2007, 10:19 PM
Is there a phone number for Ibanez?
Old 05-03-2007, 11:19 PM
IbanezGirl  is offline
Posts: 996  -  iTrader: (2)
This is worrisome news with my 550 on the way. I'll be praying like hell i don't have the pot problems Dee has had.
LOL!! That sounds sooo wrong, but you know what i mean.
Old 05-03-2007, 11:38 PM
Petie  is offline
3 just within the Jemsite community within a space of a handful of weeks seems a little suspicious to me. I'll be interested to know if you hear of any more, Rich.
Old 05-04-2007, 12:19 AM
Dee  is offline
LMFAO!
whats a good fix for a loose volume pot? john1880 Tech: Setup, Repairs and Mods 7 07-19-2006 09:45 PM
RG 2550 EGK vs. RG 2570EVSL vs. RG1570MRB vs. RG2620CBK AznGuitarist112 Other Ibanez Guitars (including Premiums) 17 03-10-2006 09:45 AM
Rg 550 vs, RG 770dx shredfreak Polls 8 08-27-2005 11:00 PM
FS : ibanez RG USA CUSTOM 1991 UCEW1FM fredperry Classified Ads: Guitars and Gear 0 05-11-2005 04:34 PM
Volume Knob problems sixstringphoenix Tech: Setup, Repairs and Mods 4 09-04-2001 12:39 AM
