Old 02-02-2006, 03:54 PM
Marq  is offline
Posts: 9  -  iTrader: (0)
volume poti
Hi everybody,
Any hints?
The volumepoti of my rg2550 is so tight to work with, that I can't use all this 'fade-in' effects. I really have to put hand on to turn volume down for e.g.
I already took a closer look at it.. couldn't solve the prob.
Best regards
Marq
Old 02-02-2006, 04:00 PM
Algiman  is offline
Posts: 2,552  -  iTrader: (14)
Re: volume poti
Was it always like that? If not give it a good blast of contact cleaner.
Old 02-02-2006, 04:03 PM
buddroyce  is offline
Re: volume poti
Sounds like you have too much crud built up in your volume pot. Try cleaning it, but if it doesn't work just replace the volume pot. Eventually pots accumulate so much crud that it's almost shot.
Old 02-02-2006, 04:04 PM
Marq  is offline
Re: volume poti
Yes, right from the beginning :-(
Isn't the contact cleaner the 'hard way'?
regards
Marq
Old 02-02-2006, 04:08 PM
Algiman  is offline
Re: volume poti
No harder than taking the scratch plate off and squirting it through the holes in the back of the pot. If it is faulty you'll have to pull the guitar apart to replace it anyway.
Old 02-02-2006, 04:10 PM
Marq  is offline
Re: volume poti
Ok, I'll try the contact spray as recommended and if it fails I'll replace it!
Thank you!
Marq
Old 02-02-2006, 04:44 PM
Marq  is offline
Re: volume poti
Thank you!
Marq
Best practice: Contact spray and 5 minutes work :-)
Thanks a lot Algiman!!!
Old 02-02-2006, 04:52 PM
Algiman  is offline
Re: volume poti
Glad to help.
scratch plate
Effects loop volume drop in Prosonic sanchez Gear and Equipment 3 05-31-2005 09:06 PM
HELP! Volume pot problem on my js1000btb. Vaislittlefinger JS (Satriani Model) Ibanez Guitars 5 03-03-2005 09:26 PM
Volume Pedals trouble311 Gear and Equipment 1 03-03-2004 04:23 PM
Volume pedal for Solo boost Dan D Mahnn Gear and Equipment 7 06-21-2003 02:03 PM
Volume Pots - 250k versus 500 Juniper570 Gear and Equipment 2 02-11-2002 10:23 AM
