Tech: Setup, Repairs and Mods
Weird Tuning Problem
08-03-2007, 01:06 PM
newbieguitarmaker
Posts: 4,030 - iTrader: (
Hey guys I have an Ibanez rg2570 setup by Rich and today I was playing and noticed my G string was out a little, the tremolo was still perfectly setup and everything. I used the fine tuner which about 4 turns from being all the way down, then my other strings went out of tune so I compensated but I kept having to make big adjustments, so I turned the fine tuners back to 0 and loosened the nut. Then I tuned from my tuners, but after I got it all perfectly in tune the tremolo is now angled wrong, it is pulling towards the strings. Why was it perfect and all of a sudden the same strings are pulling on it harder for the same notes?
newbieguitarmaker
Find all posts by newbieguitarmaker
08-03-2007, 01:11 PM
newbieguitarmaker
Re: Weird Tuning Problem
also I just adjusted my springs and tunings so my trem is set perfect but now my intonation is off mostly on my high E, and very little on my A... this is really sucky
newbieguitarmaker
08-03-2007, 01:47 PM
Posts: 19,350 - iTrader: (
You could have just emailed for tech support
Without seeing it all I can suggest is to dial everything back in. The final adjustments only last until it needs adjusting again, guitars are made of wood ya know
No idea why the intonation would be out on the E though, I seriously doubt the saddle has moved as tight as I make sure they are.
08-03-2007, 02:35 PM
newbieguitarmaker
yeah I got the trem perfect but the E is definitly out in intonation now, and trust me I would of been able to tell if it was before
it is weird because it is just a tiny bit sharp, At about the 4th fret it starts going a very small bit out then after about the 7th fret it is about as sharp as if you
palm mute
a little too far back so it goes sharp. Also I just used my tremolo and it went out of tune again but only a tad bit. I have the saddle and nut locked down perfectly so idk what could be going on.
newbieguitarmaker
08-04-2007, 01:24 AM
If the E was that sharp the saddle would be at the edge if not past the baseplate.
Are you sure you're following correct lockdown procedure?
http://www.ibanezrules.com/tech/setup/lockdown.htm
08-04-2007, 02:47 AM
newbieguitarmaker
yes I followed it exactly and I haven't had a problem through my last 2 sets of strings.
newbieguitarmaker
08-04-2007, 02:51 AM
But you're still having a problem now?
08-04-2007, 02:59 AM
newbieguitarmaker
Yeah, I'll message you tomorrow about it through email, thanks for the support so far.
newbieguitarmaker
08-04-2007, 08:14 PM
newbieguitarmaker
hey it is staying in tune now but the E string is still a little out of intonation, I guess I can deal with it lol
newbieguitarmaker
08-04-2007, 09:01 PM
dipstick
Posts: 83 - iTrader: (
Maybe you didn't stretch the strings enough.
dipstick
Find all posts by dipstick
08-04-2007, 09:04 PM
newbieguitarmaker
dipstick
well maybe, just i had the set on for like 1 or 2 weeks before this happened
newbieguitarmaker
08-05-2007, 12:18 AM
Did you check the E at the 24th while in perfect tune open?
08-05-2007, 12:26 AM
newbieguitarmaker
yeah, it is a little more sharp than open, and same amt sharp as if I do it 12th fret too
newbieguitarmaker
08-05-2007, 12:55 AM
Then detune the E, move the saddle 1/2mm toward the tail, and retune until it's back in tune, although for the life of me I don't know how it would be running sharp now. One thing about guitars is, you can't explain everything, just correct it when it happens.
08-05-2007, 01:00 AM
newbieguitarmaker
Rich I love you hahahahah, btw tomorrow my dad and I should be gathering all of my old crap together to sell so I can send you the last payment if everything sells pretty well.
Again man thanks, also just so you know ive referred many people to you for a good ibanez and a good tech
A couple of my friends might actually be buying from you later this year if they keep their mind set on it
newbieguitarmaker
palm mute
when did tom anderson introduce buzz feiten tuning system
string gauge for b tuning?
mushroomhead tuning?
is weird al really buckethead
what tuning is this beadgb
RG Prestige Tuning Stability
e2e2
02:20 PM
Tuning Problem
geetarmonkey
05:08 PM
String intonation - weird problem
carlos seo
09:13 PM
New JS Model Info - JS-2000CG
mike777
103
04-05-2002
06:50 PM
Problem with my Morley PVO - Very weird!
carlos seo
10:30 PM
05:05 AM
