Old 01-03-2008, 11:46 PM
JeffWiredBeck24  is offline
Posts: 181  -  iTrader: (1)
What Exactly Is Neck Shimming?
For some reason whenever I search on this site my browser "quits unexpectedly"; sorry if this thread has been done.
Anyway, I lowered my bridge (Lo-Pro) as far as it will go and I'm still not happy with my action. I'd like it lower, and I've seen other threads where someone says "you should shim your neck". Could someone explain exactly what this is, and how it can lower action?
Thanks.
Old 01-03-2008, 11:51 PM
jaxadam  is offline
Classified Watchdog
Posts: 3,043  -  iTrader: (9)
Re: What Exactly Is Neck Shimming?
Well, shimming the neck is not going to "lower" your action, but it's going to change the angle that you neck "acts" on the body, pickups, bridge, etc.
You might have to actually raise your bridge a hair to compensate for this new adjustment.
Old 01-04-2008, 01:39 AM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
like jax said, it's going to change how the neck is angled with the body. I made a quick visualization how it works based from my experience dealing with this subject.
The image is not to scale and is presumed the neck never had a shim and IS dead straight and all else (trem angle, bridge height, etc) is setup to near-perfection.
You'll notice the difference of angle's where the shim is placed... The black line represents a piece of paper with the thickness of a business card and the red arrow represents the trussrod adjustment necessary to make the neck straight again.
as jax suggested, you'll either have to raise or lower the bridge height depending how and if you change the angle...
lowering the bridge doesn't necessarily constitute low-action although it is part of the equation. It does affect how "easier" it is to play the guitar dependent on the strings, tuning, fretwire, and eventually, proper setup. Plus hitting rock bottom on the bridge height hinders trem-pullups
The Non-AANJ Ibby's I have always had a shim similar to the 2nd pic... if your guitar already has one, add a shim with the thickness of a folded business card.
Reg
Old 01-04-2008, 02:55 AM
^Thanks a lot guys. Very detailed.
Old 01-04-2008, 06:19 AM
IbanezFreak777  is offline
Posts: 3,486  -  iTrader: (10)
Reviews: 24
Did my Ibanez RG550 come with a shim already in the neck. Because I have pulled apart my guitar a few times, and don't remember if it had one or not ???
Old 01-04-2008, 09:54 AM
millzy  is offline
Posts: 170  -  iTrader: (0)
holy **** ive got the exact same problem, my bridge is far to low and the action not where it should be , i asked rich and he said about shiming the neck so im gonna do it soon, glad this thread was here
Old 01-04-2008, 11:53 AM
Axewielder  is offline
Posts: 60  -  iTrader: (0)
Is it best to make shims from scratch, or are there drop-in shims you can buy?
Old 01-04-2008, 12:08 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
you can cut up business cards, string packets
or fold up cooking foil - anything that works - no need to buy anything.
Old 01-04-2008, 12:16 PM
reguv760  is offline
Images: 5
Reviews: 12
If there is, it's probably stuck in the neck pocket. Depending how old your 550 is (unless it's a 20th), the paper shim ages to a certain yellow :P
Reg
Old 01-04-2008, 12:34 PM
millzy  is offline
so if i use a piece of card , (not the thick stuff, but really light), i should just fold it once and put it where exactly on the neck plate, granted that im on about the 2nd picture in the diagram?
Old 01-04-2008, 01:56 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
You may not need to fold it. Try not folding it and see how it goes. Even a thin shim can have a big effect. If the neck needs to be at more of an angle or you want to raise the bridge out of the body a little more, try a thicker shim. It's just a matter of experimenting to get it to where you want it, there are no hard and fast rules. The only thing I dislike about shims is you're decreasing the contact of wood on wood in this area. Otherwise they can be very useful for fine-tuning the feel, action, and playability.
I really need to shim my RG 20th neck, the bridge sits too low in the body and this affects my picking hand, though I hate using a shim.
Old 01-04-2008, 06:39 PM
millzy  is offline
why do you hate using a shim Dee?
i recently just did it with a 4 way fold kept really tight with double-sided tape
Old 01-05-2008, 02:47 AM
reguv760  is offline
Images: 5
Reviews: 12
might be too thick considering the double-sided tape adds a few micrometers... there's enough pressure to really "squeeze" that paper once the screws tight.
as long it works for your guitar i guess.
Reg
Old 01-05-2008, 10:47 AM
millzy  is offline
ALRIGHT LADS, I SHIMED IT LAST NIGHT! COUGH WITH A 5 FOLD AND IT WAS DISATRIOUS...IT WAS A TRIAL AND IMPROVMENT PROCESS AND WITH 3 FOLDS THE NECK WAS ANGLED IN SUCHA WAY THAT ANYTHING PAST THE 5THE FRET WAS A FLUBBED NOTE....
2 FOLDS IS THE WAY TO GO!! I FINALLY PUT A 2 FOLDER IN AND IT IS BEAUTY...PERFECT ACTION PRETTY MUCH AND MY TREM IS REASONABLY HIGH INSTEAD OF BEING RIGHT THE WAY CLUNKED INTO THE BODY!!
sorry for the font, i thought it was nesseary as this wasa big deal
Old 07-21-2008, 03:12 AM
Man, I completely forgot about this thread. I never got around to seeing if my guitar has a shim or not, but I've been having some problems with feel and playability and Dee said in an above post that a shim can be used to fix problems in these fields. My neck feels a bit, stiff right now. The action isn't ridiculously low but I'm still getting A LOT of buzz on the bass strings. Bending below the seventh fret feels stiff and rough and it just doesn't feel as nice as it used to.
Can anybody tell me what, where, how, and in what direction I should put a shim? Size of the shim? Business card, string packs, etc.?
Thanks a lot.
claw screws, floating bridges, low strings, neck angle, neck plate, neck shape, neck shim, rod adjustment, trem springs
I NEED A NECK ASAP!!! Maple fretboard and square neck joint. PatrickSimsCustomShopUSA Classified Ads: Guitars and Gear 8 08-09-2006 06:11 AM
Painted neck? Sanded neck? Drache713 Other 7-string Guitars 28 12-25-2005 12:45 AM
shimming my rg550's neck, good idea? woodros Tech: Setup, Repairs and Mods 10 03-10-2003 12:24 AM
Jem 7DBK neck confusion... Spagbol JEM and Universe Guitars 2 12-30-2002 05:48 AM
neck shimming, buzz, no low action... what to do?!? - I can' berntsen Tech: Setup, Repairs and Mods 2 04-16-2002 05:34 PM
