Tech: Setup, Repairs and Mods
What is a good way to lower a locking nut with no shims?
06-18-2008, 08:19 AM
superhairycamel
Posts: 338 - iTrader: (
just as title says.
ive got a neck that i bought from ebaey and also a locking nut of approprate radius and size. I have tried a large file but it was a very tedius and difficult task and did not remove much wood. i think i will need to remove at least 2mm of wood!
thanks guys!
superhairycamel
Find all posts by superhairycamel
06-18-2008, 10:26 AM
toneboy
Posts: 1,665 - iTrader: (
Re: What is a good way to lower a locking nut with no shims?
Don't remove wood from the neck! File the nut because if you mess that up, it can easily be replaced.
Just take your time and measure as you go.
toneboy
Find all posts by toneboy
06-18-2008, 10:56 AM
Crazy_Guitar
Posts: 1,319 - iTrader: (
Reviews: 4
toneboy
File a locking nut? Are you nuts???
File the nut pocket. Be patient and careful and always inspect your work as you go along.
You'll probably need an exacto knife to sharpen the corners.
(I did it many times...)
Good work!
11:06 AM
Crazy_Guitar
Visit Crazy_Guitar's homepage!
Find all posts by Crazy_Guitar
06-18-2008, 01:40 PM
Posts: 19,352 - iTrader: (
First I'd buy a correct nut for the neck. But I don't think there are many necks that exist you can take 2mm out of the nut channel without hitting the truss rod end. Grind the nut.
06-18-2008, 01:45 PM
Ayrton
Posts: 4,157 - iTrader: (
44
Ditto...
Buy a correct nut.
Ayrton
Find all posts by Ayrton
06-18-2008, 09:43 PM
superhairycamel
thanks guys, where do you get your
locking nuts
from?
have a good day
superhairycamel
06-19-2008, 10:51 AM
Crazy_Guitar
Reviews: 4
I have done so in a Wizard II neck from my Ibanez RG-470. I bought a OFR Pro bridge + nut pack and the nut was a bit too high.
I had to file about 2mm of wood from the neck with no problem at all. It has good clearence for the truss-rod to be adjusted.
But I guess it depends...
Check out whether you can file 2mm of wood from your neck.
Crazy_Guitar
06-19-2008, 05:20 PM
I can pretty much guarantee you won't take 2mm off an MIJ neck, and why would anybody want to screw with the expensive part when you can thin the cheap part down much more easily...... Much less taking structural strength off the thinnest part of a neck to begin with.
06-19-2008, 11:07 PM
superhairycamel
this is a $30 neck that was made in china so im not so worried about its value LOL!
superhairycamel
06-19-2008, 11:11 PM
Take a sawzall to it then
06-20-2008, 07:31 AM
Crazy_Guitar
Reviews: 4
Yes, mine is MIK. But I don't think that structurally it was affected!
superhairycamel
Ok, then... screw the whole neck up!
The best way to experiment is in cheap parts! Go for it!
Crazy_Guitar
locking nuts
why doesn't dave weiner use a locking nut?
how to lower action on peavey wolfgang
jem7dbk locking stud?
What amp sounds good with the Jemini pedal?
WTB Black Ibanez Locking Nut in good shape..
ibanezcollector
11:18 PM
Change Ibanez 550 neck locking nut for bone nut
Deep
11:14 PM
nut shims
phil27
12:10 PM
looking for shims for my UVGR locking nut - also a truss rod
Superuser
04:27 PM
Shims - I need to further lower the action
okan
03:40 PM
10:53 AM
