Re: what is a neck shim?
Toneboy mentioned a couple things a shim can be made out of..
but be careful using the wood or matchbook as he said..
because those items will get crushed as you put pressure on them.
I got a good tip recently to use a razorblade or equivalent.
(wont crush)
remember not every neck needs a shim, nor is every neck designed to have a shim
