Old 10-08-2003, 04:25 AM
Zelman  is offline
Posts: 21  -  iTrader: (0)
What is good angle of edge pro tremolo?
Hi!
My friend have Ibanez RG with new Edge Pro tremolo. He asked mi tu setup it his guitar, because it is his first guitar with FR. I have Lo Pro Edge, and i don't know what it is good angle of edge pro. If somebody acn do something like this: http://www.jemsite.com/tech/t_1setup.htm#step1
but for edge pro it will be great :)
Greetings, Adam
Old 10-08-2003, 04:27 AM
Zelman  is offline
it if of course edge pro II not Edge Pro :)
Old 10-08-2003, 04:34 AM
Ibateur  is offline
Posts: 2,947  -  iTrader: (3)
Generally speaking, as mentioned on the site, the trem angle should be neutral, regardless of type of trem, I suppose.
Cheers
Old 10-08-2003, 06:14 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
Adam,
the Edge Pro II (as the Edge Pro), should be set parallel to the top surface of the guitar.
better: the top surface of the Edge Pro II' baseplate should be set parallel to the top surface of the guitar.
Old 10-08-2003, 03:58 PM
Rich  is offline
Incorrect, the angles on the EP cause many optical illusions. Only the knife should be used to set the trem angle. That said, I don't know if you can even see the knife on the EPII.
Old 10-08-2003, 04:05 PM
jemsite  is offline
Administrator
Posts: 9,259  -  iTrader: (5)
Images: 11
just look at the diagram on the tech section in jemsite
Old 10-09-2003, 03:58 AM
nuno  is offline
the outer top edge of the EP' baseplate is perfectly parallel to the knife, then it's good as a reference.
edge pro trem, edge pro tremolo, pro edge, pro tremolo
