Old 07-09-2006, 01:47 AM
wildchild247  is offline
Posts: 408  -  iTrader: (0)
Reviews: 5
Wink
What is the best way to
clean all the gunk off your fret board
without removing strings
I find that a new strings grind the skin from my fingers and there is a lot of gunk left on the fret board
any solutions
thanks
Old 07-09-2006, 07:14 AM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
Re: What is the best way to
Ive never really cleaned the fretboard with the strings on >.> Its just a bit rough for me, I tend to use a fine toothbrush and flavor of the moment fretboard cleaner.
Old 07-09-2006, 02:11 PM
Shredder87  is offline
Posts: 417  -  iTrader: (0)
any solutions
thanks
I don't think there is a way to do it without removing all the strings! And we all know how much of a PITA that is. Ah the joys of a double-locking trem...
I have just learned to live with it.
Old 07-09-2006, 02:12 PM
Ironjose  is offline
Posts: 1,060  -  iTrader: (0)
well i use a toothbrush, a soft one.
i use to applied some wood cleaner but i notice that the fretboard stayed dry... used to do this on my first gilr but since that i havent done that with my ibz´s.
JJ
Old 07-09-2006, 02:16 PM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
Just take the strings off and put something under the trem to keep pressure on the springs, I used to use a magazine or a stack of index cards.
Old 07-09-2006, 02:18 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
1. remove strings
2. use the edge of a hard pick to scrape all the gunk off
3. use 0000 gauge steel wool to rub the surface of the board and polish the frets while youre at it
4. oil the board with bore oil
5. clean the rest of you guitar
6. put a new set of strings on
i dont know about anyone else here but I hate that "fast fret" or similar stuff, it turns your fretboard into a sh1t magnet, so dont use that crap either
do this every time you change strings and you will never have a gunky fretboard.
if ya dont, your guitar will be minging... and no-one (including you) will want to play it
I hate it when I even start to see the minutest amount of oxidation of the frets, it makes your fingers smell of metal and I hate that too...
clean regularly matey !
Old 07-09-2006, 03:17 PM
john1880  is offline
Posts: 468  -  iTrader: (1)
actually, having a double locking tremolo makes it super easy and fast to remove the strings.
i am sure it's in the tech section of www.ibanezrules.com
you pop off the springs on the tremolo, lift the tremolo out and the strings are out of the way for cleaning the fretboard. when you're done, put the trem back in place, put the springs back on and you'll probably even still be in tune.
john
Old 07-09-2006, 03:19 PM
john1880  is offline
http://www.ibanezrules.com/tech/setup/remove.htm
Old 07-09-2006, 03:57 PM
Ironjose  is offline
you can do that... remove the strings with the tremolo and voila.
JJ
Old 07-09-2006, 07:00 PM
Reviews: 5
thanks for the advice
but when I put new strings on the fret board will get really gunky
the strings being new and all
I'll only be playing a day and this would happen
what do most people do
Old 07-09-2006, 07:01 PM
Rich  is offline
Posts: 19,350  -  iTrader: (21)
Try washing your hands
Old 07-09-2006, 07:12 PM
Eggy  is offline
Posts: 1,751  -  iTrader: (0)
Try dabbing surgical spirit onto the tips of your fingers. This will toughen them up and stop them from loosing bits onto your fret board.
In other words, Toughen up Nancy boy !
Ben
Old 07-09-2006, 08:33 PM
So true! Cleaning the fretboard every string change is VERY excessive imo guys. I currently am up to 14 guitars and it would drive me INSANE to clean the fretboards every string change.
Old 07-10-2006, 02:18 AM
Reviews: 5
I have developed calices on my fingers
but after playing for a good while my fingers loose a bit of their skin
its my own problem (skin condition)
just wondering if there is an alternative to always having to change strings everytime the board gets dirty
in that case I would have to change them everyday (which is not economical)
cheers
Old 07-10-2006, 08:40 AM
Try wiping down your strings every time you've finished playing. It's normal to lose some skin after a while, it happens to me, the sweat ruins calluses, but if you wipe down your strings after you've done playing you should be fine. I do it all the time now.
double locking tremolo, ebony board, fast fret, fret board, locking tremolo, maple fingerboard, rosewood board, steel wool
