Tech: Setup, Repairs and Mods
What to do when a neck's satin finish becomes glossy?
04-24-2007, 05:14 PM
toneboy
Posts: 1,665 - iTrader: (
I've been playing my PGM301 for a little over a year now and the satin finish on the neck has become glossy and smoother and I'm not too keen on that. It doesn't have that slightly rough feel it used. I really noticed this when I got my 2nd PGM301.
I would prefer not to sand the finish off to bare wood and I don't want to get it refinished (though that might not be out of the question). I don't think that sanding a satin finish is an option (because it's thin to begin with) but if I'm wrong, please let me know.
I searched this site and didn't find any threads on this subject so any advice would be helpful.
toneboy
Find all posts by toneboy
04-24-2007, 06:04 PM
Ayrton
Posts: 4,157 - iTrader: (
44
Re: What to do when a neck's satin finish becomes glossy?
0000
steel wool
will give you what you want without removing the finish.
Ayrton
Find all posts by Ayrton
04-24-2007, 06:56 PM
buddroyce
Posts: 1,914 - iTrader: (
My suggestion is to strip the finish off and get it tung oiled.. never have to worry about dealing with a sticky glossy neck ever again.
buddroyce
Visit buddroyce's homepage!
Find all posts by buddroyce
04-25-2007, 10:11 AM
toneboy
Ayrton
0000 steel wool will give you what you want without removing the finish.
Ok, thank you for the tip. I'll give that a try.
toneboy
04-25-2007, 10:12 AM
toneboy
buddroyce
I'll probably end up going that route once I wear the neck's finish off (from playing the guitar) enough and start exposing bare wood.
toneboy
04-25-2007, 01:16 PM
Ayrton
44
Buff down the neck with the steel wool, then wipe on a couple of coats of Tru Oil. Once dry, buff again.
Tru Oil will seal the neck against moisture where
Tung Oil
will not.
Ayrton
04-25-2007, 02:15 PM
toneboy
Ah, I think I recall you mentioning that Tru Oil stuff before. If it's good enough for gunstocks I know it will be good enough for a guitar neck.
That being said, it seems that you're suggesting that buffing the neck with steel wool will take the finish off. Is that correct?
toneboy
04-25-2007, 06:15 PM
Ayrton
44
You do not have to remove the factory finish, just buff with the steel wool to knock off the shine and give the new oil something to "grab" onto. Tru Oil is very thin and you can wipe it on with a cotton cloth.
I don't know about the newer
Ibanez necks
, but the older ones have a fairly thick finish and steel wool would take forever to burn through it. If your neck has a "raw" feel to it now, the I would try just one coat of Tru Oil and see how you like that.
Ayrton
04-25-2007, 09:22 PM
toneboy
Eh, I don't believe think the finish is that thick. The finish on the PGM neck is not like the standard finish on some of the older RGs. I wonder if Rich H. will chime in considering I bought this one from him.
toneboy
04-25-2007, 11:26 PM
Ayrton
44
I stopped by GC tonight a looked at a 20th 550, and a 2550. Both guitars have a thin "raw wood" finish on the necks, so I am assuming that is what you PGM has. Knowing that, I still say a buff with steel wool and then 1-2 coats of Tru Oil followed by another buff.
For the record that is how I finish raw necks.
Ayrton
04-26-2007, 04:09 AM
jP777
Posts: 6 - iTrader: (
Hi,
I'm in the same position with my RG2820. The thin satin finish became glossy and I would like to get back to a more raw surface, and I don't really want to remove all the finish.
I'm used to play a 91 UV, which has a more raw feeling. But I think the back of the neck is oiled (is it right?).
I tried a few days ago MusicMan guitars (Axis and Petrucci) and I would like something anywhere between the MM and early UV feel.
Ayrton: is it 100% useful to put Tru Oil on it? Does the 0000 steel wool really knock off the shine of the surface, wouldn't it turn the surface even shinier? What about 400 or 600 grade sand paper? I only use 0000 steel wool to polish frets and I'm a bit scared about doing this on the neck...
thanks
jP777
Find all posts by jP777
04-26-2007, 09:49 AM
toneboy
Ayrton
Thank you again for the advice Ayrton. Sounds like that's about the safest way to get rid of the gloss.
toneboy
04-27-2007, 12:44 AM
Ayrton
44
jP777
thanks
Well steel wool is not harsh enough to remove the factory finish, but it will knock down the gloss. The Tru Oil is really just a precaution against having raw wood, and it goes on with very thin coats.
Ayrton
04-27-2007, 04:41 AM
jP777
Thank you Ayrton
I've tried yesterday on another glossy surface and buffing it with the steel wool made it smooth.
I'm gonna try this on my RG's neck this saturday, I will let you know about the result...
jP777
04-28-2007, 07:06 PM
Phishphood42
Posts: 540 - iTrader: (
Slightly OT, but I didn't want to start a new thread. I took out my guitar today and noticed that there was a slightly darker ring at the seventh fret on the back of the neck. It turns out to match my thumb perfectly, so I'm guessing its either sweat or oil from my hand that sank into the wood. How do I get rid of this? Steel wool? Its barely there but its really bothering me.
07:13 PM
Phishphood42
Find all posts by Phishphood42
ibanez neck
ibanez necks
neck finish
prestige guitar
prestige guitars
steel wool
tung oil
what people think texture finish rg2570
how to custom paint a swirl finish on a guitar
how to strip guitar finish for repaint
what paint finish use ibanez guitars
how to repair an ibanez jem 90 ham finish
RGT42DXFM Finish Question...
User010101
06:50 PM
RG Korean necks
screamndemon69
09:52 AM
Ink on satin finish neck
BigShred
10:52 PM
Satin finish in rga121
jeffry
05:09 AM
Jem7DBK Finish - Jem7DBK Finish
Teufel
12:45 PM
04:50 PM
