Old 08-09-2001, 01:50 AM
AJ Love  is offline
Posts: 119  -  iTrader: (0)
whats the difference between an F-Space pickup and a regular
I'm replacing the pickups on my RG520..someone told me I should get F-Space Dimarzio Evolutions, NOT the regular Dimarzio Evolutions?
is that correct?
whats the difference?
Old 08-09-2001, 03:11 AM
rickboot  is offline
Posts: 332  -  iTrader: (0)
One Google search and I found this on the Dimarzio site:
"F-SPACING refers to a wider spacing between pole pieces available at no extra charge on all full-sized humbuckers. F-spaced pickups should be used in the bridge position an all guitars with wider string spacing, such as STRATŪs or guitars with tremolos. This assures proper string alignment and balanced output. On guitars with a nut width of 1&amp;11/16" or greater, F-spaced pickups can used in the neck position as well. Please specify "F-spaced" at the time you place your order."
BTW, Ibanez RG guitars have a neck width of 43mm (~ 1 &amp; 11/16) so I use F-spaced in the bridge AND neck positions.
Rick
Old 08-09-2001, 03:32 AM
AJ Love  is offline
thanks Rick!!
for some reason when I searched I wasn't able to find that info
much appreciated
bridge position, dimarzio evo, dimarzio evolution, dimarzio evolutions, neck position, spaced pickup
