Re: Wiring diagram for 4&16 ohm mono and 8 ohm stereo cab?
What your saying is doable, but what ohms are you looking for in the end? Does it matter? If you parallel two speakers that are 4ohms each - you're down to 2ohms per side...which is why cabs that do this start with 16 ohms speakers....(it'd only go down to 8ohms). You don't kill (I should say overwork) your output transformer with tiny loads like 2ohms.
As far as the out, for more options you could mount a switch to configure the out as series or parallel to the other cab you use by flicking a switch.
I could draw all this out for you but I wouldn't know how to post it.
