Old 03-08-2007, 06:39 AM
jlander  is offline
Posts: 77  -  iTrader: (0)
Wiring Diagram Questions - Schaller 5 way Switch - RG370
Hi, im installing an Schaller 5 way Switch, has 8 poles to connect, one for ground, one input, and 6 poles for the pickups.
Ive got a tester and it makes no sense, i cant find the single coil position? why is that??
any one has a wiring diagram for an RGX70 2humb 1 sing with this switch?? but on ly two pole humb, im using INFs Ibanez
thyanks!
Old 07-07-2010, 01:20 AM
Rotek12  is offline
Posts: 1  -  iTrader: (0)
Re: Wiring Diagram Questions - Schaller 5 way Switch - RG370
Hi, schaller are a fairly simple switch, you have identified the earth tag and also the tags numbered from 1 to 7. Standard wiring for a 5 way is as follows: - (4) is your hot out to your volume pot, tag (1) is your hot from the bridge PU, tag (5) is the hot from your Mid PU, and (7) is your hot from the neck PU. Enjoy, Rotek
wiring diagram
Ibanez RG 5 way switch wiring? (pics) kamix Pickups & wiring 10 03-29-2010 01:42 AM
JPM wiring on a tele switch, is this diagram right? marianozz Pickups & wiring 3 05-27-2006 06:10 PM
jem 7 wiring diagram questions Koss Pickups & wiring 0 09-08-2005 01:21 AM
wiring diagram requests DSTARSONG Pickups & wiring 1 08-10-2004 04:20 PM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 05:59 PM
