Go Back   Jemsite > Toolbox: Setup, Repairs and Mods > Tech: Setup, Repairs and Mods
Old 12-23-2000, 08:43 PM
jay ratkowski jay ratkowski is offline
Posts: 2,091  -  iTrader: (7)
Wiring help needed... - for Legacy 4x12 cabs
I'm trying to find a way to make my Legacy cab have 2 inputs. *They come with 1 input and 1 output. *I want 2 mono inputs... so each input would go to all 4 speakers.
If it helps any, each speaker is 16 ohms, and the entire cab is 16 ohms. *
Can anyone help?
Old 12-23-2000, 09:36 PM
tommy west tommy west is offline
Posts: 85  -  iTrader: (0)
What are you trying to do with this Jay?
I could see two inputs if you split the speakers in half to make it a stereo cab.
You would have signal from two power amps going to the same set of speakers in effect. No workie.....
Do you have more details?
Old 12-23-2000, 10:19 PM
Can't have two heads going into one speaker even if the watts and ohms match up? *
Hmm... might have to just sell the damn Legacies...
Old 12-24-2000, 01:52 PM
rgr rgr is offline
Posts: 1,726  -  iTrader: (9)
Didn't you bring up this topic in the last forum? *The answer is the same as in the "2 Amps, 1 cab... Special AB Box" topic you started in the gear section of the old forum. *
I would bet that the 1 input, 1 output jacks on the Legacy cabs are wired the way you want. *They are both connected across all the speakers, not sure why they marked them in and out. *They are wired that way so you can use a mono amp (Legacy) and plug into one cab and then run a speaker cable from that cab to another cab, this would make it a parallel load of 8 ohms. *I don't own a Legacy but cabs have been made like this since the early Marshalls, it's pretty standard unless it's a stereo cab which the Legacy isn't.
If you plug a head into each of the jacks you have now put the output transformer of the unused amp into the circuit, that means you are dumping the signal from the amp you are playing through into the output of the one that's not being used, not healthy for the amp. *You've hooked 2 GOES-OUTTAs together. *
I thought you were talking to Bob Bradshaw about a special signal routing box? *That's the only way you are going to be able to do something like this.
Roger
Dean Vendetta XMT Electric Guitar with Vintage Tremolo Metallic Black
As low as $159
at 10 sellers
ESP LTD B Bass Universal Case
As low as $89
at 3 sellers
Members with more than 50 posts don't see this bar
ESP LTD KH-602 Kirk Hammett Signature Series Guitar Black
As low as $850
at 8 sellers
Traveler Escape EG-1 Travel Electric Guitar White
As low as $430
at 7 sellers
Hal Leonard 3 Doors Down Away From The Sun Guitar Tab Songbook
As low as $12
at 9 sellers
Breedlove Atlas Series Studio J350/CR Jumbo Acoustic-Electric Guitar Natural
As low as $799
at 8 sellers
Line 6 Variax Workbench 1.5
As low as $100
at 10 sellers
Hal Leonard Guitar School Eric Johnson Book
As low as $11
at 9 sellers
Cherry Lane Hawthorne Heights: The Silence In Black and White Guitar Tab Songboo
As low as $11
at 8 sellers
Dunlop Nickel Plated Steel Electric Guitar Strings - Medium Heavy
As low as $2
at 10 sellers
Gibson Vintage Gold Machine Heads with Pearloid Buttons
As low as $60
at 4 sellers
Seymour Duncan SFX-03 Twin Tube Classic Preamp Pedal
As low as $219
at 7 sellers
BC Rich Celtic Virgo Electric Guitar Onyx
As low as $385
at 10 sellers
Schecter Hellraiser Solo-6 Electric Guitar Black
As low as $749
at 9 sellers
power amp, power amps, speaker cab
close
Sign up for free and join one of the largest communities of Jem guitar lovers!
Our members will be glad to help you with anything you need!
Join over 30,000 JemSite members!
Email
Email Confirm Email
Username
Password Confirm Password
I agree to the website rules
