Old 01-30-2008, 05:14 PM
TMatt142  is offline
Posts: 544  -  iTrader: (4)
Images: 2
ZR problems.....
So I'm doing my annual take the S-470 apart and do a tune-up. When I got the strings off, I noticed that the saddle on the D string is loose. Upon further check I see that the holding bolt hole is ovaled thus, the saddle cannot be tightened down!! Now I've never had to mess with the saddles so somehow or another, this bolt worked loose enough and then I imagine the string tension on the saddle ovaled the hole. This is an S-470 with a ZR trem. I'm wondering if they make saddle holding bolts that are longer?? I didn't see any on the Ibanez web site. You guys ever have anything like this happen?
Old 01-30-2008, 07:53 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Re: ZR problems.....
So you are saying the threaded hole the bolt goes into is ovalled (as opposed to the head of the bolt)? That's pretty strange. And it was never like that before?
You could certainly try a longer bolt. If you can't find one locally, you can try the web hardware vendors. Not a lot else you can do except install a helicoil.
Ask Rich.
Old 01-30-2008, 09:15 PM
TMatt142  is offline
Images: 2
yep, the threaded hole is ovalled. It is weird. Probably means it was loose in the saddle for quite some time.
Old 01-30-2008, 09:22 PM
Rich  is offline
I kinda doubt this. If you pull the bridge out you'll see all the saddle screws run into a threaded steel [not zinc] plate under the trem.
Old 01-31-2008, 09:56 AM
TMatt142  is offline
Images: 2
Yep, I noticed that Rich just not sure how this happened cause I know I've never messed with the saddles. I'm bummed now, cause I was thinking about selling it to afford my 7-string habit. Now I've gotta fix this first. Any suggestions?
Old 01-31-2008, 01:30 PM
Rich  is offline
As has already been said, helicoil, or try and find out the part number for the plate and order another.
string tension
Amp problems or guitar problems? Vermillion Gear and Equipment 5 01-25-2006 10:09 PM
Having problems with trem angle... Adagio_777 Tech: Setup, Repairs and Mods 13 09-20-2005 06:33 AM
my new js and problems cakewalkr7 JS (Satriani Model) Ibanez Guitars 1 01-08-2004 01:47 PM
new trem problems...from a different perspective btweensunandmoon Tech: Setup, Repairs and Mods 11 05-13-2003 12:47 AM
tuning problems are over - new guitar chip james JEM and Universe Guitars 2 02-01-2001 10:48 PM
