Buy, Sell or Trade
Comments to Ibanez
Ibanez design improvements
Comments to Ibanez
Here is your chance to post your comments to Ibanez. Officially this topic is NOT endorsed, approved or monitored by Ibanez/Hoshino. That said, voice your opinion anyway.
Please be courteous
Page 1 of 3
03-07-2007, 05:59 PM
Satchriossi
Posts: 294 - iTrader: (
First of all, i love my ibanez guitars! But, design improvements i would ask for are;
Stronger neck to body joint - i have had problems with tuning stability due to the neck of my 2005 RG1520 moving in the neck pocket - i have solved the problem with shims since but i think the neck should extend under the neck pickup into a deeper pocket perhaps to prevent side to side movement. The neck pocket isn't perfectly carved out either, so manufacturing tolerances should be improved in this area.
The piezo elements in the
edge pro bridge
saddles that are part of the Roland GK pickup in the RG1520 are made of too soft a metal. The strings wore significant grooves into the saddles within two weeks of playing which led to the strings being pinched in the grooves and throwing the tuning out every time the whammy bar was used. I solved the problem by using 'saddle singer' inserts but think this definately needs to be sorted on any future guitars ibanez produces that are fitted with Roland GK synth pickups.
I would like to see locking studs fitted to future Japanese built
Ibanez guitars
with floating vibrato systems.
Thanks very much
Satchriossi
Find all posts by Satchriossi
03-07-2007, 08:02 PM
alex10
Posts: 698 - iTrader: (
Re: Ibanez design improvements
Satchriossi
I would like to see
locking studs
fitted to future Japanese built Ibanez guitars with floating vibrato systems.
Thanks very much
+111111111111111111111111111111111111111111111
alex10
Find all posts by alex10
03-07-2007, 08:13 PM
fettouhi
Posts: 9,937 - iTrader: (
We all want locking studs
Regards
André
fettouhi
Find all posts by fettouhi
03-07-2007, 08:33 PM
Roland
Posts: 617 - iTrader: (
You're saying DESIGN improvements, yeah? I want a more drastic lower horn cutaway, and less extension on the horn as well (lower, that is). Possibly a little scoop-out on the horn on the body side to keep the wrist from bumping in (Yeah yeah, whatever, the Cooley-cutaway).
I stand FIRM on the first one.
Roland
Find all posts by Roland
03-08-2007, 06:51 AM
nuno
Posts: 4,725 - iTrader: (
Roland
You're saying DESIGN improvements, yeah? I want a more drastic lower horn cutaway, and less extension on the horn as well.
you're talking about the RG? then FORGET IT and get a Talman! an RG with a less extended lower horn... HAHAHA!
Roland
that cutaway scoop was done in some Petrucci's custom Ibanezs already. hopefully they won't ever do it.
nuno
Visit nuno's homepage!
Find all posts by nuno
03-08-2007, 09:39 AM
timi_h
Posts: 1,104 - iTrader: (
i think making the bottom cutaway thinner (thinner as in the depth of the wood) would solve that and not change the guitar aesthetically, unless that was what you meant by a scoop!
and nuno why do you hope the wont ever do that?
timi_h
Find all posts by timi_h
03-08-2007, 11:27 AM
Tubarão Guitars
Posts: 3,965 - iTrader: (
cooley cutaway behind the lower horn is a great improvement!
i'll gonna do it on my next custom guitar!
Tubarão Guitars
Visit Tubarão Guitars's homepage!
Find all posts by Tubarão Guitars
03-08-2007, 04:12 PM
fettouhi
I know this off topic (a bit) but I'm gonna mention it again. A improvement could be to offer more lefties and do yearly variations of those (both high-end and low-end guitars)
Regards
André
fettouhi
03-08-2007, 11:49 PM
Drow Swordsman
Posts: 741 - iTrader: (
fettouhi
Regards
André
+1!!
And again, I have to admit - for all of the fussy arguments Ibanez has made that lefties are "expensive to produce" on a broad range, somehow Carvin USA guitars manage to feature that option with ZERO charge and can be had for right around the Prestige price range?
I'm right handed but I definitely feel it for the lefties out there.
Drow Swordsman
Find all posts by Drow Swordsman
03-09-2007, 12:09 AM
chone
Posts: 194 - iTrader: (
Drow Swordsman
+1!!
Carvin guitars
are available direct only and are made to order. This means they make only as many lefty guitars as they sell. Ibanez, on the other hand, makes a crap load of guitars and sends them to dealers (essentially). This means they run a risk of making
too many
lefty guitars and could lose money.
chone
Find all posts by chone
03-09-2007, 12:10 AM
Dee
Posts: 8,514 - iTrader: (
Drow Swordsman
+2. I'm also a righty but I feel sad for the lefties. I think something like 1 in 18 people are left handed. Is that correct?
chone
Carvin guitars are available direct only and are made to order. This means they make only as many lefty guitars as they sell. Ibanez, on the other hand, makes a crap load of guitars and sends them to dealers (essentially). This means they run a risk of making
too many
As I suggested on the Ibanez forum, make lefties to order.
Dee
Find all posts by Dee
03-09-2007, 04:08 AM
chone
Dee
Oh I'd agree with that. I just thought it was unfair for Drow to compare carvin to ibanez like that.
chone
03-09-2007, 08:09 AM
fettouhi
Dee
Thank you!!!
Regards
André
fettouhi
03-12-2007, 09:35 AM
projectjem
Posts: 664 - iTrader: (
[quote=nuno;623492]you're talking about the RG? then FORGET IT and get a Talman! an RG with a less extended lower horn... HAHAHA!
"i think i'll have fry's 'lower horn' jerked."
"wooooo. its used to it. wooooooooooo"
projectjem
Find all posts by projectjem
03-12-2007, 11:49 AM
Roland
nuno
What's up with your bloody condescending tone?
Roland
Page 1 of 3
bridge saddles
carvin guitars
custom guitar
custom ibanez
edge pro bridge
edge zero
fretboard wood
ibanez guitars
left handed guitar
locking stud
locking studs
neck pickup
string guitars
ibanez zps dont flutter?
step by step how to relic a guitar design
compare ibanez grx40 squier telecaster affinity
design JEM guitar how to
how many Ibanez guitars do you own?
spacenuke
1534
01-22-2012
05:08 PM
Ibanez & Vai timeline of events - working together
jemsite
Archived Topics and Common Questions - GO HERE FIRST
03:38 PM
Did Ibanez cheap out with their stock pickups? [no, they're DiMarzio made for Ibanez]
TheJazzTerminator
224
08-18-2006
07:48 PM
ibanez guitars,a design team only?
MERCYFULFATE
Comments to Ibanez
03:47 PM
Ibanez in Vanity Fair?!?
Kevan
Comments to Ibanez
12:06 AM
11:02 AM
